Maximum number of LOCAL variables?
03-09-2014, 06:48 AM
I am getting syntax errors in a program that has more LOCAL variables than I have used before, and the error cursor always goes to a variable in my LOCAL variable list. named maxheight I can find no flaw in the variable (but, who knows?). Several questions come to mind:
Is there a maximum number of permitted local variables? If so, what is it?
Can a LOCAL list be split and continued on a second or third line? If so, how?
What IS the maximum line length permitted in a Prime program?
Does the language permit the inclusion of more than one LOCAL statement?
These seem to be pretty basic questions, but I cannot find information about them in the "User Guide." Is there any more comprehensive source of information??
Many thanks for information on these.
Ben Fairbank
03-09-2014, 06:59 AM (This post was last modified: 03-09-2014 07:00 AM by eried.)
RE: Maximum number of LOCAL variables?
You can use any local statements you want.
local aa,ab;
local ac;
local ad:=1;
local ae:=aa,af:=ab;
Post your code, the error is probably in another line.
My website: erwin.ried.cl
03-09-2014, 07:20 AM
maximum is 8 variables in a LOCAL line.
as many LOCAL lines as you need.
Patrice
“Everything should be made as simple as possible, but no simpler.” Albert Einstein
03-09-2014, 08:15 AM
Eried --
Thank you for the suggestion.
Here are the lines I think are most likely to be giving the error:
LOCAL pp, qq, xcor, pi, denom, height, num, xmode, maxheight,propheight,
finalheight; [this is all on one line]
many lines omitted
// Plot the distribution:
FOR X FROM 15 TO 303 STEP 1 DO
xcor := (X-15)/288;
num := (xcor^(pp-1))*((1-xcor)^(qq-1));
propheight := num/(denom*maxheight);
finalheight := 160 - propheight*156;
PIXON(X,finalheight);
PIXON(X,(finalheight+1));
The above lines simply step through X-axis lines from 0 to 1 and plot the distribution of the y variable associated with X.
If I comment these lines out, AND remove their variables from the LOCAL list, the syntax error stops appearing.
Ben
03-09-2014, 11:47 AM
As patrice said, you have to split that local in 2 (8 vars max per local)
