PDF on Hp Prime:how is it possible?
07-11-2017, 07:54 AM
Is it possible to upload files.pdf on Hp Prime Graphing Calculator? If so, how can I do this?
Many thanks
07-11-2017, 08:55 AM
RE: PDF on Hp Prime:how is it possible?
The pdf reader is not suppprted by the official firmware, but you can try to write a pdf-reader by yourself or convert it to png/jpg on the computer.
07-11-2017, 09:05 AM
(07-11-2017 08:55 AM)wangchong01 Wrote:  The pdf reader is not suppprted by the official firmware, but you can try to write a pdf-reader by yourself or convert it to png/jpg on the computer.
After converting the pdfs how can I upload them by the HP connectivity kit, and how to see them on the calculator?
many thanks
07-11-2017, 09:19 AM
You can upload the picture with an app and use Gallery to read it(http://www.hpcalc.org/prime/graphics/galleryv210.zip)
I found a pdf converter just now but I don't know whether it will work(https://www.omnimaga.org/hp-prime/mviewe...-hp-prime/)
07-11-2017, 09:44 AM
(07-11-2017 09:19 AM)wangchong01 Wrote:  You can upload the picture with an app and use Gallery to read it(http://www.hpcalc.org/prime/graphics/galleryv210.zip)
Sorry for my incompetence, how can I put this app on the calculator?
07-11-2017, 09:50 AM
Download it and put it to the folder c:/users/<your user name>/documents/hp connectivity kit/content (if you are using windows 7 or above). Then you can drag it to the HP Prime.
By the way, can you upload the mviewer app? I can't get access to the tiplanet.org Sad
07-11-2017, 10:16 AM
Unfortunatly I am Mac OS user... I tried to do this, it seems I have to update my firmware, but to do this I should have to connect the calculator with a windows computer cause from Mac is it possible to upgrade only from the second to last firmware
07-11-2017, 10:18 AM (This post was last modified: 07-11-2017 10:19 AM by COB160.)
I don't know what mviewer is and do not know this site ? ?
07-12-2017, 04:46 AM
(07-11-2017 10:16 AM)COB160 Wrote:  Unfortunatly I am Mac OS user... I tried to do this, it seems I have to update my firmware, but to do this I should have to connect the calculator with a windows computer cause from Mac is it possible to upgrade only from the second to last firmware
I think you can update your firmware on your Mac. I found that the mViewer is not a pdf reader but a pdf-png converter. You can just copy it to the hpappdir of gallery and upload it to the calculator.
