a request to make programming faster....
07-18-2017, 11:45 AM
Accessing cas functions through the cas variables is fine, but you should have the cas variables in the toolbox cas menu, so the programmer doesn't have to enter an entirely different menu, find cas vars, select view and then click on the name....
07-18-2017, 12:09 PM
RE: a request to make programming faster....
From another post I've posted, I see that even cas vars doesn't allow you to put the name into a program or put it on the command line....it just shows the definition. We already have programs to do that.....how do you get the name from a menu without having to type it? Slows programming down incredibly....
When that is solved....put THAT in the toolbox menu....
