HP-41 Copy files from Hepax ram to 41
07-29-2017, 04:53 PM
Hi
Is there a way to copy program from the Hepax RAM back to the HP-41 I do miss a HGETP as option to HSAVEP. Sine I have a corrupt file in one Hepax RAM file on go41cx, I would like to get it back to the HP-41, so I can create a new RAM file and copy it back there. |
07-29-2017, 05:21 PM
RE: HP-41 Copy files from Hepax ram to 41
(07-29-2017 04:53 PM)Jotne Wrote: Hi I am not sure if this will work with a corrupt file... but normally the HP41 COPY function is designed to copy a FOCAL program from ROM to RAM. HEPAX treats programs in its RAM as ROM programs, so I think the standard COPY command should work here. If not, maybe some other expert on HEPAX can chime in! Greg |
07-29-2017, 05:52 PM
Greg is correct here, COPY "PRG-NAME" will copy your program (PRG-NAME) from the HePaX RAM to main RAM.
Now if your HePaX RAM is corrupted, you can either
HePaX RAM brute force reset & assuming HePaX RAM are between page 8 and 11
Sylvain |
07-29-2017, 08:54 PM
It worked nice. I do have the program on other RAM, so I can make all back to one healthy module.
