[34S] "Running..." can't display it off?
03-13-2014, 05:10 PM
I use a long sequence of PROMPTs in my what-if analysis. When I R/S to the next one the alpha display briefly shows "Running..". I tried alpha-OFF/ON to avoid the resulting screen flicker. I want to go directly from one prompt message to the next one without the "Running..".
I searched Walter's pdf & p.69, but no such luck. Anyone know? - Sikuq |
03-13-2014, 06:37 PM
RE: [34S] "Running..." can't display it off?
(03-13-2014 05:10 PM)Sikuq Wrote: I tried alpha-OFF/ON to avoid the resulting screen flicker. Try VWα+ X directly after the STOP. This will replace the "Running" message quickly. It will not avoid flicker completely but should reduce it. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
03-13-2014, 08:22 PM
(This post was last modified: 03-13-2014 08:24 PM by Sikuq.)
Quote:Try VWα+ X directly after the STOP. This will replace the "Running" message quickly. It will not avoid flicker completely but should reduce it. Marcus, Thank you for your suggestion of VWα+X. Although I do understand your line of thought it did not seemingly work. It could be that the duration is already almost minimal (but I am a perfectionist). However I still learned about the VWα+X by reading your response, so thanks. -Sikuq |
