(50g) OEIS A028842: Product of Digits is a Prime
09-05-2017, 02:43 PM
(This post was last modified: 09-10-2017 11:34 AM by Gerald H.)
For integer input N the programme returns the Nth element of the series
https://oeis.org/A028842 where the elements are all numbers in naturally ascending order whose product of digits is a prime. I am particularly unhappy with this 4. OVER WHILE DUP2 < REPEAT OVER - SWAP 4. + SWAP END section of code & would welcome a speedier method of calculating the 2 numbers deposited on the stack. SIZE 173. CKSUM # 502Fh Code: « 4. OVER |
09-05-2017, 09:21 PM
(This post was last modified: 09-06-2017 04:50 AM by Joe Horn.)
RE: (50g) OEIS A028842: Product of Digits is a Prime Sequence
(09-05-2017 02:43 PM)Gerald H Wrote: I am particularly unhappy with this For input X, it returns two numbers A and B. An algorithm that generates A from X is this: 2. / √ 0 RND 4 * Its accuracy is limited by its use of real square roots. Rewriting it for integer accuracy, and generating B from X and A, are left as exercises for the student. EDIT: I wrote that because I was having a devil of a time figuring out how to do it! It finally dawned on me after staring at the numbers long enough. Here's a routine that inputs X and outputs X, A, B: Code: DUP 2. / √ DUP 0. RND 4. * SWAP .5 + FP OVER * CEIL The bigger the input, the larger the speed difference. For an input of 1E7, the loop takes 11 seconds, and the direct approach takes 0.022 seconds, 500 times faster. EDIT 2: Due to roundoff errors, this routine gets incorrect results for large inputs. Don't trust the output for inputs > 1E11. It seems to be ok for anything smaller than that. <0|ɸ|0> -Joe- |
09-06-2017, 05:43 AM
Brilliant, Joe! Thank you.
Resulting in the programme below. The round off error will not be relevant in this programme as 50g has too little memory to find 20,000 digit numbers. Code: « DUP 2. / √ DUP 0. |
09-06-2017, 06:27 AM
{I totally understand how this program works!} COERCEFLAG {Best programme I've ever seen! This programme has changed my life! Before I used this programme I was a bum, now I'm a multi-millionaire!} {Well done!} IFTE
<0|ɸ|0> -Joe- |
09-06-2017, 11:57 AM
Very nice, problem solved up to limit of 50g's memory.
But is it? For input 35918081 the programme returns 11111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111112111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111 which is correct, but where's the 2? Aha! There it is. OK, so where is it? Position please. Standard decimal number system is unsuited to large numbers. Accordingly the programme below for the same input returns :# Digits: 4238 (total number of digits in answer) :Pos: 1318 (position of the non-1 digit, counting from right) :Digit: 2 (the embedded prime digit) which I think displays the answer more clearly. So we can now represent the answer for much larger input given some way of getting Joe's programme to work exactly. Suggestions welcome. Size: 185.5 CkSum: # 9CBBh Code: :: |
09-06-2017, 03:44 PM
Joe's programme snippet can be replaced by
Code: :: Putting that in the initial user programme gives Code: « DUPDUP 2. / √ 0. |
09-06-2017, 06:43 PM
& here a version which for input
35918081 returns :# Digits: 4238 (total number of digits in answer) :Pos: 1318 (position of the non-1 digit, counting from right) :Digit: 2 (the embedded prime digit) & is free from approximate arithmetic. ID SQR0 is an integer square root programme you can find here: http://www.hpmuseum.org/forum/thread-8992.html Size: 273.5 CkSum: # 3973h Code: :: |
09-07-2017, 10:00 AM
A slightly improved version of the programme:
Size: 267.5 CkSum: # DCE9h Code: :: |
09-07-2017, 12:08 PM
What do you mean with "improved", what is the metric? Only the size?
Wikis are great, Contribute :) |
09-07-2017, 12:14 PM
Size, elegance & speed.
