Interesting....reverse engineered USB protocols
09-06-2017, 04:15 AM
...for the HP Prime...
https://github.com/eried/PrimeComm
09-06-2017, 04:23 AM
RE: Interesting....reverse engineered USB protocols
This is also related to it...
http://services.ried.cl/primecomm/Help/?...85662e.htm
09-06-2017, 02:24 PM
Its changed quite a bit since then. The underlying commands not so much, but we discovered that the windows HID driver just silently loses packets on occasion. Thus there is not a layer on top that will bounce back and forth between the connkit and usb calculator to request packets that were missed.
I believe the original as implemented there will still work, but it won't be as reliable or take advantage of later features like compression during transmission and similar.
TW
