Loading [MathJax]/extensions/Safe.js
(38G) OEIS A262389: Last Digit Composite
09-08-2017, 05:45 AM (This post was last modified: 09-10-2017 11:33 AM by Gerald H.)
The programme inserts symbolics in the Sequence App to produce the sequence of numbers having right-most digit composite.
For more info please see
https://oeis.org/A262389
RECURSE(U,U2(N-2),4,6)►U1(N):
CHECK 1:
RECURSE(U,U3(N-2),8,9)►U2(N):
RECURSE(U,U3(N-1)+U2(N-2)-U1(N-1),14,16)►U3(N):
09-13-2017, 02:06 PM
RE: (38G) OEIS A262389: Last Digit Composite
The 3 recursions can be telescoped into one, producing a faster method of generating the series.
RECURSE(U,IFTE(N>5,U1(N-1)+U1(N-4)-U1(N-5),IFTE(N==5,14,IFTE(N==4,9,8))),4,6)►U1(N):
CHECK 1:
Although I find the first version more pretty.
09-13-2017, 04:06 PM (This post was last modified: 09-13-2017 04:07 PM by Didier Lachieze.)
Here is a direct formula tested on the Prime as I don't have a 38G:
U(N)=10*IP((N-1)/4)+2*(N MOD 4)+7*NOT(N MOD 4)+2
09-13-2017, 06:09 PM (This post was last modified: 09-14-2017 05:37 AM by Gerald H.)
Bravo Didier!
On 38G you must have brackets around (NOT(N MOD 4)) then it works OK.
I tried a formula, but yours beats mine.
Here's mine:
RECURSE(U,(5*N+1-U2(N)+(3+U2(N))*U2((2*N-3-U2(N))/4)/2)/2,4,6)►U1(N):
CHECK 1:
RECURSE(U,IFTE(N MOD 2,-1,1),-1,1)►U2(N):
just for the record.
09-14-2017, 06:25 AM
Explicitly, this is what Didier's formula should look like on the 38G:
RECURSE(U,(10*INT((N-1)/4)+2*(N MOD 4)+7*NOT N MOD 4)+2
,4,6) ►U1(N):
CHECK 1:
09-14-2017, 06:45 AM
Didier, perhaps you should inform OEIS of your formula, as it's more elegant than any on their webpage.
