HP-41 rechargable battery
09-11-2017, 05:36 PM
Did you realize that there are two different battery packs for the HP-41? One has 2 charging pins, the other has 3 pins. Both are coded HP82120A.
I'm currious as the charger for this unit has only 2 pins... the middle pin of the 3 pin version is absolutly "useless". Matthias |
09-11-2017, 05:42 PM
(This post was last modified: 09-11-2017 05:43 PM by Sylvain Cote.)
RE: HP-41 rechargable battery
(09-11-2017 05:36 PM)HP-Collection Wrote: Did you realize that there are two different battery packs for the HP-41? One has 2 charging pins, the other has 3 pins. Both are coded HP82120A. Hello Matthias, You can find the information on the HP82120A with two pins here and with three pins here. Sylvain |
09-11-2017, 05:55 PM
(09-11-2017 05:36 PM)HP-Collection Wrote: Did you realize that there are two different battery packs for the HP-41? One has 2 charging pins, the other has 3 pins. Both are coded HP82120A. Of course we know, Matthias. My first one was a 3-pins design. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
