(38G) OEIS A228297: An Interesting Irregular Sequence
09-19-2017, 05:08 PM
(This post was last modified: 09-21-2017 05:28 AM by Gerald H.)
These three programmes together produce the Online Encyclopaedia of Integer Sequences' sequence A228297.
The first programme takes a positive integer input from any previous calculation & finds the integer quotient for division by 5. eg If you enter 77 on the home screen, the programme returns 15 as Ans, which you can see on the Home screen after pressing SHIFT ENTER. Code: IQUOT5 The next programme takes a positive integer, eg 67, input from any previous calculation & calculates eg the 67th member of the OEIS sequence A27868. https://oeis.org/A027868 Code: A27868 Thr third programme takes a positive integer, eg 777,777,777,777, input from any previous calculation & calculates eg the 777,777,777,777th member of the OEIS sequence A228297, making use of the two programmes above. https://oeis.org/A228297 Code: A228297 |
