Fibonacci numbers without programming
09-20-2017, 03:13 PM
Amazingly, most of simple non-scientific calculators allow to produce sequence of Fibonacci numbers with only 2 key press per number:
AC 1 + = + = + = ...
On HP 17b I found solutions with 6 keys per number:
For init: 0 ENTER 1 ENTER
Next number: SHIFT LAST + SHIFT LAST =
How to do this on RPN calculators like HP 12C, HP 42S (without programming)?
09-20-2017, 03:51 PM
RE: Fibonacci numbers without programming
With a RPN calculator you can do:
1 ENTER 1 + LASTx x<>y + LASTx x<>y + ...
09-20-2017, 04:11 PM
It worked. Good solution.
Thanks you!
09-20-2017, 05:03 PM (This post was last modified: 09-20-2017 05:03 PM by Dieter.)
(09-20-2017 03:13 PM)stored Wrote:  How to do this on RPN calculators like HP 12C, HP 42S (without programming)?
On calculators with RCL-arithmetics and direct stack access (e.g. the 42s) you can do this:
1 ENTER +
RCL+ ST L
RCL+ ST L
RCL+ ST L
Depending on the model this may take the same four keys as the Lastx x<>y + method... or maybe less: on the WP31s and 34s it's simply [RCL] [+] [L].
Dieter
09-20-2017, 07:41 PM
On the RPL series, if you enter two 1's on the stack, the sequence OVER OVER + will fill the stack with the Fibonacci series. Three key presses if you have the PROGRAM/STACK menu active.
09-20-2017, 08:34 PM
(09-20-2017 07:41 PM)John Keith Wrote:  On the RPL series, if you enter two 1's on the stack, the sequence OVER OVER + will fill the stack with the Fibonacci series. Three key presses if you have the PROGRAM/STACK menu active.
Or two, if you do DUP2 + instead.
Gerson.
09-20-2017, 08:55 PM
Any blind programmable CASIO:
[1][KIN][1]
Then repeat the following:
[+][x↔K1][=]
Csaba
09-20-2017, 09:54 PM
If you have a matrix math capable calculator, fill the stack with:
[[1 1]
[1 0]]
and press "X" (multiply) repeatedly. A one button solution!
09-20-2017, 10:05 PM
Gerson.
DOH! That's what I get for posting first, thinking later. :-)
09-20-2017, 10:38 PM
(09-20-2017 09:54 PM)Jim Horn Wrote:  If you have a matrix math capable calculator... A one button solution!
What I really like about this solution is that it does not rely at all on the coeffificents in the recursion being 1 or on the order of the recursion being only 2. That's the difference between doing math and doing arithmetic :-)
09-20-2017, 10:40 PM (This post was last modified: 09-20-2017 10:46 PM by Gerson W. Barbosa.)
(09-20-2017 10:05 PM)John Keith Wrote:
(09-20-2017 08:34 PM)Gerson W. Barbosa Wrote:  Or two, if you do DUP2 + instead.
Gerson.
I have many “OVER OVER” sequences permanently written in the files, like this one here (third code box in post #20). Yet DUP2 was available in my first RPL calculator, a 28S. Hopefully I’ll never forget :-)
09-20-2017, 11:18 PM
(09-20-2017 09:54 PM)Jim Horn Wrote:  If you have a matrix math capable calculator, .... A one button solution!
I really like this one: so general. The difference between doing math and arithmetic :-)
02-17-2018, 03:17 PM
On any HP RPN Calculator can do Fibonacci Sequence manually without the use of program.
Key this in and repeat second line below.
1 ENTER 1 ENTER RollDown RollDown +
ENTER ENTER RollDown RollDown +
Gamo
02-17-2018, 04:49 PM
However, with a short program, one can get any Fibonacci number by entering the index. (Except for overflow).
<< 5 Sqrt 1 + 2 / SWAP ^ 5 Sqrt / 0 RND>>
02-19-2018, 06:29 PM
(09-20-2017 08:55 PM)Csaba Tizedes Wrote:  Any blind programmable CASIO:
[1][KIN][1]
[+][x↔K1][=]
Csaba
A shorter solution for the FX-180P line:
Repeat:
x↔y =
Calculator Benchmark
02-28-2024, 12:19 AM (This post was last modified: 02-28-2024 12:30 AM by Thomas Klemm.)
From Musings on the HP-70:
Fibonacci Sequence
Initialisation
DSP 0
CLR
STO M
1
Loop
M+
x<>y
Result
0.
1.
1.
2.
3.
5.
8.
13.
21.
34.
References
02-28-2024, 12:53 AM
After setup, press Enter once to generate each subsequent Fibonacci number.
[Image: Fibo.png]
<0|ɸ|0>
-Joe-
