convert fractional power to radical
09-27-2017, 03:04 PM
Can displayed results with fractional powers be shown with an equivalent radical (√) sign, instead? Is there a toggle for this?
-Dale- |
10-22-2017, 05:41 PM
(This post was last modified: 10-22-2017 05:42 PM by salvomic.)
RE: convert fractional power to radical
(09-27-2017 03:04 PM)DrD Wrote: Can displayed results with fractional powers be shown with an equivalent radical (√) sign, instead? Is there a toggle for this? do you mean symbolic results? I'm curious too how to obtain conversion, i.e., from 1/(x^3) into [3]√x or thing like that... \( x^{\frac{1}{3}} \space \text{::} \sqrt[3]{x} \) ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
10-22-2017, 06:39 PM
Yes. I haven't found a way to do that.
10-22-2017, 10:00 PM
If it's in there it'd be in one of the algebraic expansion functions.
10-24-2017, 02:49 AM
There is a way to do this in a program. You'd have to write a function as follows...
Convert the expression to a string. Then, wherever NTHROOT shows up in the string, substitute for dd NTHROOT x with x^(1/dd). Likewise, to go the other direction, search for x^(1/dd) and convert to dd NTHROOT x, still in string format. Then call EXPR on the result. Enjoy. Publish this if you write it :-) |
10-28-2017, 03:15 PM
(This post was last modified: 10-28-2017 03:35 PM by salvomic.)
I'd like to have something like QPI (see here), but more general (also for x and variables) and ...built in in the CAS. Maybe someday... who knows?
![]() Salvo EDIT: however, for now, i.e., in Home QPI(x^(½)) returns 0, in CAS it, after some time, returns "Error: insufficient memory"... and no result. ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
10-30-2017, 06:12 AM
The problem is that this is a hard nut to crack and can yeild fairly long calculations. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
10-30-2017, 07:53 AM
(This post was last modified: 10-30-2017 08:22 AM by salvomic.)
(10-30-2017 06:12 AM)cyrille de brébisson Wrote: Hello, Certainly, Cyrille, we understand that, however having radicals result would be useful. ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
