(11C) (15C) Tip Calculation
10-07-2017, 06:45 AM (This post was last modified: 10-09-2017 01:14 AM by Gamo.)
This is a simple program for tip calculation that took the idea from HP 12C Platinum vertical mode calculator app with Tip functions.
LBL A for Bill Amount
LBL B for Tip%
LBL C for Split (if only yourself enter 1)
LBL D answer for Tip per Person
LBL E answer for Total per Person
LBL A [Bill]
STO 1
RTN
LBL B [Tip%]
STO 2
RTN
LBL C [Split]
STO 3
RTN
LBL D [>Tip]
RCL 1
RCL 2
RCL 3
RTN
LBL E [>Total]
RCL 1
RCL 2
RCL 3
RTN
Total bill is $90.45 with 15% tip and 2 person
Example: 90.45 f A [Bill], 15 f B [Tip%], 2 f C [Split]
Answer: f D result 6.78 per person [Tip], f E result 52.01 per person[Total]
Quick Change: If you decided to lower the [Tip%] to 10% just press 10 f B and result for [Tip per person] and [Total per person] get the update result.
Now press f D result 4.52 per person [Tip], f E result 49.75 per person [Total]
Gamo
10-07-2017, 10:13 AM
RE: (11C) (15C) Tip Calculation
(10-07-2017 06:45 AM)Gamo Wrote:  This is a simple program for tip calculation that took the idea from HP 12C Platinum vertical mode calculator app with Tip functions.
LBL B for Tip%
LBL C answer for Total per Person
Quote:LBL A [Bill]
STO 1
RTN
LBL B [Tip%]
STO 2
RTN
LBL C [Split]
STO 3
RTN
LBL D [>Tip]
RCL 1
ENTER
RCL 2
RCL 3
RTN
LBL E [>Total]
RCL 1
ENTER
RCL 2
RCL 3
RTN
Quick Chagne: If you decided to lower the [Tip%] to 10% just press 10 f B and result for [Tip per person] and [Total per person] get the update result.
Gamo
Just look at the label Instructions, for the last corresponds LBL E instaed LBL C. Pedro
10-07-2017, 02:10 PM
Pedro Thank You that was typo.
I'm making change to LBL E
Gamo
10-08-2017, 07:53 AM (This post was last modified: 10-08-2017 07:55 AM by Dieter.)
(10-07-2017 02:10 PM)Gamo Wrote:  Pedro Thank You that was typo.
You also can (and should) remove the two ENTERs at LBL D and E.
BTW, this program will also work on other HPs with label keys, such as the HP67 and 97.
Dieter
10-08-2017, 09:04 AM (This post was last modified: 10-08-2017 11:33 AM by Gamo.)
Dieter Thank You
I update the program now no ENTER
On the HP 67 and 97 even better when using Labels like this program because don't have to press f then LBL just go straight to each labels that very convenience.
Gamo
10-08-2017, 06:48 PM (This post was last modified: 10-08-2017 07:01 PM by Dieter.)
(10-08-2017 09:04 AM)Gamo Wrote:  I update the program now no ENTER
Fine. Please also consider your other program for calculators without label keys.
(10-08-2017 09:04 AM)Gamo Wrote:  On the HP 67 and 97 even better when using Labels like this program because don't have to press f then LBL just go straight to each labels that very convenience.
Switch to User mode and it's the same on the 11C and 15C. ;-)
P.S.: I'm a big fan of compact code, so here's another version.
Works on most calculators with R↑ key and does not require any registers.
R↓
LastX
R↑
X<>Y
LastX
90,45 [ENTER] 15 [ENTER] 2 [R/S]
=> 52,01 [X<>Y] 6,78
What? No R↑ key? Replace R↑ with 3x R↓.
Dieter
10-09-2017, 01:24 AM (This post was last modified: 10-09-2017 01:40 AM by Gamo.)
Dieter Thank You
That shorter program is very compact one.
For this program I try to make the same input steps of the Tip Calculator on the HP 12C Platinum Vertical Mode.
On HP 12CP user key in 3 variables and get the answer for the other 2 variables.
Thank You
Gamo
10-10-2017, 12:57 PM (This post was last modified: 10-10-2017 01:05 PM by Dieter.)
(10-09-2017 01:24 AM)Gamo Wrote:  That shorter program is very compact one.
On the 41/42 it can be even shorter:
R↓
ST+ Y
R↑
ST/ Z
=> 6,78 [X<>Y] 52,01
On the 42s you even see both results at the same time.
(10-09-2017 01:24 AM)Gamo Wrote:  For this program I try to make the same input steps of the Tip Calculator on the HP 12C Platinum Vertical Mode.
OK, so post your new version here.
Dieter
10-10-2017, 09:28 PM
For HP 67 longer program and shorter output procedure ==>
R↓
LastX
R↑
X<>Y
LastX
R/S
X<>Y
So ==> Input: 90.45 [ENTER] 15 [ENTER] 2
Output: [R/S] 52.01 [R/S] 6.78
Pedro
