HP 49G Series: Update of 48G Exmath
10-13-2017, 06:42 AM
Is now available here
http://www.hpcalc.org/details/8702
10-13-2017, 01:16 PM
RE: HP 49G Series: Update of 48G Exmath
(10-13-2017 06:42 AM)Gerald H Wrote:  Is now available here
Why no version for the 2.15 ROM for the 49G+ and 50g? This is the latest (and final) version and believe 2.15 is by far the most common version in use today.
10-13-2017, 04:19 PM
I don't have a 50g with 2.15 ROM.
I believe 2.10-7 is the same, except for the Apps, having the Geometry App but not the one for data collection.
Perhaps someone could test Exmath on a 50g with 2.15?
10-13-2017, 05:18 PM (This post was last modified: 10-13-2017 05:18 PM by Gerald H.)
I have cursorily tested Exmath on Android go49g+ OS 2.15 & so far all seems OK.
10-13-2017, 06:36 PM
(10-13-2017 04:19 PM)Gerald H Wrote:  I don't have a 50g with 2.15 ROM.
Why not update your 50g to ROM 2.15? Although there is always a small chance a new version could add a new bug, this version definitely fixed many bugs, so why not use the better version?
Is there some advantage to using the older version (other than you are more familiar with it)?
10-13-2017, 07:30 PM
Well, 2-10-7 does have the Geometry App, I consider that a small plus.
I don't know if any bugs were removed between 2-10-7 & 2.15. In the .pdf file included with 2.15 there is a Change Log list, but no bugs, except for that introduced in 2.14, have been fixed since 2.10, so I presume 2.10-7 is as bug-free as 2.15. Do you have any further documentation?
In this thread
http://www.hpmuseum.org/forum/thread-9195.html
posts 10, 11 & 15 Joe Horn believes my 50g is faster than his. I don't know how great the variance in speed is between different 50gs using the same OS, nor indeed between different OSs.
Perhaps 2.10-7 is faster?
10-13-2017, 07:34 PM
I forgot to say that I also have 2.10-7 installed on my 49G.
10-13-2017, 07:43 PM
Both 2.10-7 & 2.15 have this Easter egg:
https://www.thecalculatorstore.com/Calcu...-the-HP50g
10-13-2017, 07:51 PM
But this Easter egg
seems to have been removed in 2.15, at least on the go49g+ emulator.
10-13-2017, 09:57 PM
(10-13-2017 07:51 PM)Gerald H Wrote:  But this Easter egg
Still here (50g #2.15).
10-14-2017, 02:15 AM
(10-13-2017 09:57 PM)Gerson W. Barbosa Wrote:  Still here (50g #2.15).
Confirmed on both a 50g and 49g+ running 2.15.
I think I recall seeing a list of bugs fixed in 2.15 but can't find it now. Perhaps I'm mistaken about that, but I do know at that stage, HP was only patching the 50g ROM if absolutely necessary (as there was literally no free ROM space left, so every single change took lots of work) so I'm fairly sure the 2.15 release was driven by bug fixes, even if they weren't acknowledged in public docs.
10-14-2017, 04:59 AM (This post was last modified: 10-14-2017 05:01 AM by Gerald H.)
Also present in Android emulator, don't know why I didn't find it yesterday, but doesn't seem to work correctly, causing reboot.
10-14-2017, 03:19 PM
Should anyone install the library I would be grateful for feedback, particularly if there should be any bugs.
I've used the library for some years, incrementally improving & adding functions & not noticed any bugs for some time.
10-14-2017, 03:37 PM (This post was last modified: 10-14-2017 03:50 PM by Gerson W. Barbosa.)
Quoting from
http://www.hpcalc.org/details.php?id=7097
Quote:·Renumbered for a supported release version (C215)
·Fixed Port2 writing interrupt problem introduced last revision. (C214-2)
·Removed 49G boot loader code and ‘easter egg’ pictures from Bank0 to make room for Streamsmart application and future enhancements. (C214)
·SIMPLIFY Fix for 1/(0.5+sqrt(1-cos(x)^2)), also fixing simplify(0.5*sin(2x)/(0.5+sin(x))) (C210)
·Fix issue when running embedded SUM: SUM(N=0,3,SUM(M=0,N,COMB(N,M-N)) (C210)
·Fix Linear Solver when importing symbolic matrix (C210)
·Ask the user to convert the matrix to an array in the input form (C210)
·Reverse variable order for LINSOLVE to return solution in the original order (C210)
·LINSOLVE help fixed (3 stack levels returned instead of 1) (C210)
·Remove check for battery level when storing data onto flash, SD card or using IO. (C210)
·Added new mechanism in ChooseBox menu to allow entry to create 48G style menu. Used by EqnLibrary (C210)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=192 (C209)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=193 (C209)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=206 (C209)
·Fix FSEEK: (C208)
·Fix 48GX full screen choose and mini-font (C207)
·Fix (B206)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=201 (B206)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=113 (B205-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=44 (B205-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=89 (B205-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=115 (B205-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=134 (B205-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=140 (B205-3)
·Fix corrupted screen when entering a multi-line command line in old Input Form (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=96 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=143 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=147 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=72 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=84 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=108 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=112 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=138 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=145 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=110 (B205-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=102 (B204-6)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=133 (B204-6)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=141 (B204-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=131 (B204-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=128 (B204-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=114 (B204-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=111 (B204-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=110 (B204-5)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=106 (B204-1)
·Fix http://bugs.hpcalc.org/show_bug.cgi?id=102 (B204-1)
·anti-debouncing threshold is now by default 139ms with 20ms interrupt timer. This value can now be controlled with ->KEYTIME (build 86)
·Fix a problem in BlankDA2 (C2.02)
·Fix problem where Flash could get corrupted when storing a user object (B2.03-2)
·Fix variable X will be deleted during warmstart (B2.03-6)
·Export entry point MAKELIST to retrieve list of files (including from SD card) (B2.03-7)
·Fix Disp5x7 and DISPN can't use the new 80 lines screen (B2.03-8)
·Fix naming case issue when storing files on SD card (Build 85)
·Fix SD card Fat32/Fat16 access not exactly following Microsoft specification (build 85)
·Fix shift modifier key was pushed with other modifiers where it shouldn't
·Fix GBASIS bug (C-2.01)
·Fix EQW NEGNEG was wrongly deleted when first argument of + or - (C-2.01)
·Fix CLKADJ (C-2.01)
Gerson.
10-14-2017, 08:05 PM
Why not write better libraries for NEWRPL?
http://hpgcc3.org/projects/newrpl
10-15-2017, 02:20 AM
(10-14-2017 03:37 PM)Gerson W. Barbosa Wrote:  Quoting from
Quote:...many bug fixes
Gerson.
Thanks Gerson, I knew I read that somewhere. Probably should have looked first in the exact place it should be...
10-15-2017, 07:55 AM
(10-14-2017 03:19 PM)Gerald H Wrote:  Should anyone install the library I would be grateful for feedback, particularly if there should be any bugs.
The documentation says that after executing the EXMATH command, numbers are entered by pressing the "the B key (2nd menu key)". But that's not true for the 50g version of the library, which shows the "%" function on the B key. I can't find any key combination that lets you enter numbers.
Also, the doc says that the 5th menu key is Exit. It's not.
So I can't enter numbers at all, and I can't exit. Please help.
<0|ɸ|0>
-Joe-
10-15-2017, 09:02 AM (This post was last modified: 10-15-2017 09:06 AM by Gerald H.)
To ENTER a number:
Right Shift (Orange) then F1
demands a mantissa & then an exponent.
To EXIT:
Right Shift (Orange) then F6.
A further change is the position of SWAP which is now
Right Cursor Key.
10-15-2017, 09:07 AM
Thank you, Joe, I'll update the documentation.
10-15-2017, 09:13 AM
(10-15-2017 09:02 AM)Gerald H Wrote:  To ENTER a number:
To EXIT:
Thank you!
<0|ɸ|0>
-Joe-
