(12C) Stirling's approximation
10-24-2017, 05:35 AM (This post was last modified: 10-24-2017 09:15 AM by Gamo.)
For when you need answer from Decimal Factorial with your HP 12C
From Wikipedia:
In mathematics, Stirling's approximation (or Stirling's formula) is an approximation for factorials. It is a good-quality approximation, leading to accurate results even for small values of n.
Program:
ENTER
2488320
CHS
STO 1
139
ENTER
51840
CHS
STO 2
288
1/x
STO 3
12
1/x
STO 4
CLx
R/S
ENTER
STO 5
2
x
355
ENTER
113
x
Sqr
RCL 5
RCL 5
2
Y^x
STO 6
x
RCL 5
e^x
1/x
x
RCL 6
x
STO 7
RCL 5
1/x
ENTER
ENTER
ENTER
RCL 1
x
RCL 2
x
RCL 3
x
RCL 4
x
1
RCL 7
x
GTO 37
Example: Clear Register f [REG]
[R/S] result 0 (Initialize)
2.34! ------> 2.34 [R/S] result 2.7976......
4.32! ------> 4.32 [R/S] result 39.2945....
5.43! ------> 5.43 [R/S] result 254.0337...
Gamo
11-04-2017, 05:26 AM (This post was last modified: 11-19-2017 01:44 AM by Gamo.)
RE: (12C) Stirling's approximation
N! approximation using Forsyth's formula with shorter program steps.
STO 1
ENTER
X
RCL 1
6
1/x
√x
1
e^x
RCL 1
0.5
Y^X
2.5066283
x
Example: input N [R/S]
2.34! ------> 2.34 [R/S] result 2.7971......
4.32! ------> 4.32 [R/S] result 39.2928....
5.43! ------> 5.43 [R/S] result 254.0266...
Gamo
11-04-2017, 02:01 PM
(11-04-2017 05:26 AM)Gamo Wrote:  N! approximation using Forsyth's formula with shorter program steps.
Instead of 2 [y^x] you should use [ENTER] [x] which is much faster (and sometimes even more accurate). And why don't you simply use 6 [1/x] instead of 0,1667 ?-) Finally, once again the ENTER is not required and should be omitted.
This leads to the following version, here with a few more digits in sqrt(2pi) and without any registers:
ENTER
ENTER
x
LastX
6
1/x
√x
1
e^x
X<>Y
0.5
Y^X
2.5066283
x
GTO 00
This gets even a tiiiny bit closer to the true results:
2.34 [R/S] => 2.7971...
4.32 [R/S] => 39.2931...
5.43 [R/S] => 254.0287...
And it accurately overflows for x > 69,95757445
Dieter
11-05-2017, 07:39 AM
Dieter Thank You
Totally forgot about 1/6 by using [ 1/x ]
And your program is really improve the accuracy.
Gamo
11-06-2017, 01:41 PM
(11-05-2017 07:39 AM)Gamo Wrote:  Totally forgot about 1/6 by using [ 1/x ]
To be honest, the change in accuracy is negligible. The essential message was: please, do not use 2 [y^x] for squaring. [ENTER] [x] is much faster, sometimes more accurate and it even sets LastX correctly.
Dieter
