User Key: Custom Menu
11-03-2017, 12:43 PM
You can assign a custom menu to a user key. The program TEMPLATES assigns a list of functions to the templates key (the key to the right of the Toolbox key, key 18 I believe).
When this program is completed, you call the custom menu by pressing [Shift], [Help] (User), [template key].
Choose a function or command. Whatever you choose will be inserted into the entry line. This user key works in program editing as well.
HP Prime Program: TEMPLATES
Note: I do not have a main “TEMPLATES” program block. In terms of making a custom menu like this, it is not necessary.
// a custom menu
// 2017 EWS
KEY K_Templ()
LOCAL str,lst,cst,ch;
// templates
lst:={"Function.ROOT()",
"Function.AREA()",
"Function.SLOPE()",
"Finance.TvmNbPmt()",
"Finance.TvmIPYR()",
"Finance.TvmPV()",
"Finance.TvmPMT()",
"Finance.TvmFV()"};
// choose list
cst:={"ROOT",
"AREA",
"SLOPE",
"N",
"I%YR",
"PV",
"PMT",
"FV"};
CHOOSE(ch,"Template",cst);
RETURN lst(ch);
Link to original post: http://edspi31415.blogspot.com/2017/11/h...st-of.html
11-03-2017, 08:21 PM
RE: User Key: Custom Menu
That's awesome!
11-04-2017, 06:38 AM
(11-03-2017 12:43 PM)Eddie W. Shore Wrote:  You can assign a custom menu to a user key. The program TEMPLATES assigns a list of functions to the templates key (the key to the right of the Toolbox key, key 18 I believe).
// a custom menu
// 2017 EWS
KEY K_Templ()
// templates
"Function.AREA()",
"Function.SLOPE()",
"Finance.TvmPV()",
"Finance.TvmPMT()",
"Finance.TvmFV()"};
// choose list
cst:={"ROOT",
"AREA",
"SLOPE",
"N",
"I%YR",
"PV",
"PMT",
"FV"};
RETURN lst(ch);
Bonjour
Excellente idée, merci.
Hello
Great idea, thank you.
Sorry for my english
11-26-2017, 03:59 AM (This post was last modified: 11-26-2017 04:00 AM by Tyann.)
Bonjour
Pour le nouveau firmware Je vous propose une amélioration qui permet de quitter sans faire de choix avec 'ESC'
Hello
For the new firmware I propose an improvement that allows you to leave without making a choice with 'ESC'
// a custom menu
// 2017 EWS
KEY K_Templ()
LOCAL r,str,lst,cst,ch;
// templates
"Function.AREA()",
"Function.SLOPE()",
"Finance.TvmPV()",
"Finance.TvmPMT()",
"Finance.TvmFV()"};
// choose list
cst:={"ROOT",
"AREA",
"SLOPE",
"N",
"I%YR",
"PV",
"PMT",
"FV"};
r:=CHOOSE(ch,"Template",cst);
IF r THEN
 RETURN lst(ch);
ELSE
 RETURN -1
05-11-2018, 08:03 AM
Nice enhancement.
Note that you need a semicolon after the RETURN -1 in the third last line viz:
 RETURN -1;
otherwise it is a syntax error.
