Calling a CAS function in a program
11-04-2017, 01:30 AM
(This post was last modified: 11-04-2017 08:26 PM by eulus.)
I'm trying to write an HP program that numerically solves a system of nonlinear equations using the CAS function fsolve, with certain parameters depending on local variables (inputs). I get an "Error: Bad Argument Value" when trying to run the program, despite the same system getting solved just fine when I type it into CAS. The only thing I could find online was this post, where they discussed issues with using local variables in CAS functions, but nothing definitive was reached. Here's my code for reference: Code:
Thanks! |
11-04-2017, 04:41 PM
RE: Calling a CAS function in a program
I don't think you can use Home local variables as unknowns for fsolve. Make a CAS program and use CAS global variables (or CAS local variables and purge them).
