Best Regression Fit
11-04-2017, 02:08 PM
Best Regression Fit
The program BESTFIT compares a set of regressions to determine a best fit. This simulates a feature presented on the Hewlett Packard HP 48S, HP 48G, HP 49G, and HP 50g. BESTFIT compares the correlations of the following four regression models:
1. Linear: y = a * x + b
2. Logarithmic: y = a * ln x + b
3. Exponential: y = b * a^x (y = b * e^(ln a * x))
4. Power: y = b * x^a
The output is a two element list: a string of the best fit equation and its corresponding correlation.
HP Prime Program: BESTFIT
EXPORT BESTFIT(L1,L2)
// 2017-11-02 EWS
// Simulate Best Fit
// HP 48GX,49G,50g
// initialize
LOCAL clist,m,c,v,s,n;
clist:={0,0,0,0};
// test
// correlation is linear only
// requires approx()
// linear y=a*x+b
clist[1]:=approx(correlation(L1,L2));
// log y=a*LN(x)+b
c:=approx(correlation(LN(L1),L2));
IF IM(c)==0 THEN
clist[2]:=c;
// exponential y=b*e^(a*x)
c:=approx(correlation(L1,LN(L2)));
IF IM(c)==0 THEN
clist[3]:=c;
// power y=b*a^x
c:=approx(correlation(LN(L1),LN(L2)));
IF IM(c)==0 THEN
clist[4]:=c;
// test
// POS(L0^2,MAX(L0^2))
m:=POS(clist^2,MAX(clist^2));
c:=clist[m];
IF m==1 THEN
v:=linear_regression(L1,L2);
s:=STRING(v[2])+"+"+STRING(v[1])+
"*X";
RETURN {s,c};
IF m==2 THEN
v:=logarithmic_regression(L1,L2);
"*LN(X)";
RETURN {s,c};
IF m==3 THEN
v:=exponential_regression(L1,L2);
s:=STRING(v[2])+"*"+STRING(v[1])+
"^X";
RETURN {s,c};
IF m==4 THEN
v:=power_regression(L1,L2);
s:=STRING(v[2])+"*X^"+
STRING(v[1]);
RETURN {v,s};
BESTFIT2: An Extended Version
Version 2 adds the following regressions:
5. Inverse: y = b + a/x
6. Simple Logistic: y = 1/(b + a*e^(-x))
7. Simple Quadratic: y = b + a*x^2
8. Square Root: y = √(a*x + b)
HP Prime Program: BESTFIT2
EXPORT BESTFIT2(L1,L2)
// 2017-11-02 EWS
// HP 48GX,49G,50g
// additional models
// initialize
LOCAL clist,m,c,v,s;
clist:={0,0,0,0,0,0,0,0};
// test
// linear y=a*x+b
// log y=a*LN(x)+b
IF IM(c)==0 THEN
clist[2]:=c;
IF IM(c)==0 THEN
clist[3]:=c;
// power y=b*a^x
IF IM(c)==0 THEN
clist[4]:=c;
// inverse y=b+a/x
IF POS(L1,0)==0 THEN
clist[5]:=approx(correlation(1/L1,
L2));
// simple logistic
IF POS(L2,0)==0 THEN
clist[6]:=approx(correlation(e^(−L1),
1/L2));
// simple quadratic
clist[7]:=approx(correlation(L1^2,
L2));
// square root
IF ΣLIST(L2≥0)==SIZE(L2) THEN
clist[8]:=approx(correlation(L1,
L2^2));
// test
c:=clist[m];
IF m==1 THEN
"*X";
IF m==2 THEN
"*LN(X)";
IF m==3 THEN
"^X";
IF m==4 THEN
STRING(v[1]);
// inverse
IF m==5 THEN
v:=linear_regression(1/L1,L2);
"/X";
// simple logistic
IF m==6 THEN
v:=linear_regression(e^(−L1),
1/L2);
s:="1/("+STRING(v[2])+"+"+
STRING(v[1])+"*e^(−X))";
// simple quadratic
IF m==7 THEN
v:=linear_regression(L1^2,L2);
"*X^2";
// square root
IF m==8 THEN
v:=linear_regression(L1,L2^2);
s:="√("+STRING(v[2])+"+"+
STRING(v[1])+"*X)";
RETURN {s,c};
Link: http://edspi31415.blogspot.com/2017/11/h...n-fit.html
11-04-2017, 03:51 PM
RE: Best Regression Fit
thanks Eddie,
good program.
It works better in Home: I tried in CAS with the second list with a series of LN() and it return "Error: Bad argument type", the same input is good in Home, however. Please, control it.
Salvo
12-17-2017, 04:17 PM
Very interesting program. I missed that feature on the HP Prime, till now.
I´ve done a little modification for better input data.
EXPORT BESTFIT2()
// 2017-11-02 EWS
// HP 48GX,49G,50g
// initialize
EDITMAT(M1,{"INTRODUZCA LOS DATOS",{},{"X","Y"}});
L1:=mat2list(col(M1,1));
L2:=mat2list(col(M1,2));
// test
// linear y=a*x+b
// log y=a*LN(x)+b
IF IM(c)==0 THEN
clist[2]:=c;
IF IM(c)==0 THEN
clist[3]:=c;
// power y=b*a^x
IF IM(c)==0 THEN
clist[4]:=c;
// inverse y=b+a/x
L2));
// simple logistic
1/L2));
// simple quadratic
L2));
// square root
L2^2));
// test
c:=clist[m];
IF m==1 THEN
"*X";
IF m==2 THEN
"*LN(X)";
IF m==3 THEN
"^X";
IF m==4 THEN
STRING(v[1]);
// inverse
IF m==5 THEN
"/X";
// simple logistic
IF m==6 THEN
1/L2);
// simple quadratic
IF m==7 THEN
"*X^2";
// square root
IF m==8 THEN
STRING(v[1])+"*X)";
RETURN {s,c};
12-27-2017, 03:31 PM (This post was last modified: 12-29-2017 03:52 AM by Namir.)
Here is my version of BESTFIT. It iterates over many powers for Y and X, including powers with fractions.
EXPORT BESTFIT(Mat, IdxX, IdxY)
// initialize
L1:=mat2list(col(Mat, IdxX)); // X
L2:=mat2list(col(Mat, IdxY)); // Y
LOCAL Lx, Ly;
LOCAL xpwr, ypwr, ix, iy, xscale, yscale;
LOCAL xminIdx, xmaxIdx, yminIdx, ymaxIdx;
LOCAL r2, coeffs;
LOCAL bestR2, bestXpwr, bestYpwr;
// combination of index ranges and scales should iterate
// in range -4, -3.5, -3, ..., -0.5, 0, 0.5, 1, 1.5, ..., 4
// Adjust these values as you see fit
xminIdx := -8;
yminIdx := -8;
xmaxIdx := 8;
ymaxIdx := 8;
xscale := 0.5;
yscale := 0.5;
bestR2 := -1;
FOR iy FROM yminIdx TO ymaxIdx DO
   // Transform Y values
   ypwr := iy * yscale;
   IF iy == 0 THEN
     Ly := LN(L2);
   ELSE
     Ly := L2^ypwr;
   FOR ix FROM xminIdx TO xmaxIdx DO
     xpwr := ix * xscale;
     // Transform X values
     IF ix == 0 THEN
       Lx := LN(L1);
     ELSE
       Lx := L1^xpwr;
     r2 := approx(correlation(Lx, Ly))^2;
     if r2 > bestR2 THEN
       bestR2 := r2;
       bestXpwr := xpwr;
       bestYpwr := ypwr;
       coeffs := linear_regression(Lx, Ly);
       IF r2==1 THEN
         RETURN {bestR2, bestYpwr, bestXpwr, coeffs[1], coeffs[2]};
The function requires the name of a data matrix and the indices of the columns that select X and Y data. The function returns:
1) Best Rsqr value.
2) Best power for Y. Please note that a 0 means ln(x).
3) Best power for X. Please note that a 0 means ln(x).
5) Slope for best curve.
6) Intercept of best curve.
The fitted models are in the general form:
Y^ypwr = intercept + slope*X^xpwr
When ypwr or xpwr is 0, the term represents a natural logarithm.
You can alter the range for the loops, the scales for X and Y as you see fit. Just make sure you don't try to raise negative values to negative powers or powers with fractions. If you have date the best thing to do is to scale their values to be in the range of 1 to 2, using:
x(i) = 1 + (x(i) - min(x))/(max(x) - min(x))
y(i) = 1 + (y(i) - min(y))/(max(y) - min(y))
Such a scaling ensures that all transformations will not generate a run time errors.
Enjoy
Namir
12-27-2017, 09:14 PM (This post was last modified: 12-29-2017 03:53 AM by Namir.)
RE: Best Regression Fit version 2
The next version of the best fit, BESTFIT2, tests the power model between X and Y first, before testing all other transformations. If you have negative values in either X or Y the do not use this function:
EXPORT BESTFIT2(Mat, IdxX, IdxY)
// initialize
LOCAL Lx, Ly;
LOCAL r2, coeffs;
xminIdx := -8;
yminIdx := -8;
xmaxIdx := 8;
ymaxIdx := 8;
xscale := 0.5;
yscale := 0.5;
// Test power model first
bestR2 := approx(correlation(LN(L1), LN(L2)))^2;
bestXpwr := 0;
bestYpwr := 0;
coeffs := linear_regression(LN(L1), LN(L2));
   IF iy == 0 THEN
     Ly := LN(L2);
   ELSE
     Ly := L2^ypwr;
     IF ix == 0 THEN
       Lx := LN(L1);
     ELSE
       Lx := L1^xpwr;
     IF r2 > bestR2 THEN
       bestR2 := r2;
       bestXpwr := xpwr;
       bestYpwr := ypwr;
       IF r2==1 THEN
I wrote this modified version because while testing Y=X^2, I was getting 1/Y^2 = 1/X^4 as the best model. While the answer is theoretically correct, it is not in the desired form.
Namir
12-28-2017, 12:54 PM (This post was last modified: 12-29-2017 03:53 AM by Namir.)
Here is a third version, BESTFIT3, that maps the X and Y data to values in the range of (1, 2), making all transformations possible:
1) Best Rsqr value.
2) Power of best Y transformation (0 means ln(y)).
3) Power of best X transformation (0 means ln(x)).
4) Best slope.
5) Best intercept.
6) Minimum X value.
7) Maximum X value.
8) Minimum Y value.
9) Maximum Y value.
Make sure you use the powers, slope, intercept, minima, and maxima in estimating Yhat values:
Yhat' = (slope * ((X-xmin)/(xmax-xmin)+1)^xpwr + intercept)^(1/ypwr)
Yhat = ymin + (Yhat'-1)*(ymax-ymin)
if xpwr=0 and ywpr!=0 use:
Yhat' = (slope * ln((X-xmin)/(xmax-xmin)+1) + intercept)^(1/ypwr)
if xpwr!=0 and ywpr=0 use:
Yhat' = exp(slope * ((X-xmin)/(xmax-xmin)+1)^xpwr + intercept)
if both xpwr and ypwr are zero, use:
Yhat' = exp(slope * ln((X-xmin)/(xmax-xmin)+1) + intercept)
Use ln() functions when xpwr s 0 and use exp() when the ypwr is 0.
EXPORT BESTFIT3(Mat, IdxX, IdxY)
LOCAL Lx, Ly;
LOCAL r2, coeffs;
LOCAL xmin, xmax, ymin, ymax;
// initialize
xmin:=MIN(L1);
xmax:=MAX(L1);
ymin:=MIN(L2);
ymax:=MAX(L2);
// Map data into (1,2) range
L1:=L1-xmin;
L1:=L1/(xmax-xmin)+1;
L2:=L2-ymin;
L2:=L2/(ymax-ymin)+1;
xminIdx := -8;
yminIdx := -8;
xmaxIdx := 8;
ymaxIdx := 8;
xscale := 0.5;
yscale := 0.5;
bestXpwr := 0;
bestYpwr := 0;
IF bestR2==1 THEN
  RETURN {bestR2, 0, 0, coeffs[1], coeffs[2], xmin, xmax, ymin, ymax};
   IF iy == 0 THEN
     Ly := LN(L2);
   ELSE
     Ly := L2^ypwr;
     IF ix == 0 THEN
       Lx := LN(L1);
     ELSE
       Lx := L1^xpwr;
     IF r2 > bestR2 THEN
       bestR2 := r2;
       bestXpwr := xpwr;
       bestYpwr := ypwr;
       IF r2==1 THEN
         RETURN {bestR2, bestYpwr, bestXpwr, coeffs[1], coeffs[2], xmin, xmax, ymin, ymax};
