Taylorani
11-08-2017, 11:29 PM
Taylorani
According to the newly arisen problems with Geometry and catalog I decided to try my old (2015) app Taylorani which now all of a sudden decided not to work like expected, so I added some slight changes.
The program displays a (hopefully) animated Taylor approximation of a function that can be entered via View: Input Data. There is sine without using input and cosine preselected in input. The idea comes from the program with the same name from the 49g+/50 series where I sometimes used it and Geometry seemed to be the best base. If the animation doesn't start, which from time to time happens as the slider for that is not displayed, I found best to open the program in the editor and directly close the editor again, selecting Symb was helpful, too. If "all" measures don't help, pm me so that I can try to find a workaround. |
