Probability
11-10-2017, 07:39 PM
Probability
Go figure:
Suppose an 8.5 ton Chinese space station went out of control, and re-entered the Earth's atmosphere. If the predicted debris impact zone could be anywhere within the boundaries of 43° North latitude, and 43° South latitude, and given this event occur's some time next year, with other orbital parameters not known at this time, what are the chances, any particular spot, within the boundary, will be hit with debris remnants? Not being wise in the ways of this field of study, does this problem even have a feasible solution? Zoner's, keep your hard-hat ready! https://www.thesun.co.uk/tech/4676492/ch...ist-warns/ |
11-11-2017, 07:05 AM
(This post was last modified: 11-11-2017 07:08 AM by AlexFekken.)
RE: Probability
Back-of-the-envelope/gut-based calculation says: extremely small...
EDIT: this is taking into account the "law of conservation of debris", i.e. there is only so much debris that won't be burned up and hits earth. |
11-11-2017, 08:44 AM
(This post was last modified: 11-11-2017 11:58 AM by Didier Lachieze.)
RE: Probability
Here is a quick program to calculate, based on your estimated number of debris reaching earth, the probability to be hit by a debris on a 1m² area:
Code: EXPORT Tiangong1(N) //N: estimated numbers of debris reaching earth EDIT: I initially wrongly multiplied p by 0.3 (70% of Earth being oceans) but the % of oceans doesn't change the probability of a given square meter area to be hit by a debris. |
11-11-2017, 10:17 AM
RE: Probability
Didier,
I am always amazed at your knowledge, skills, and abilities. You have combined all three, to make this challenge simple and understandable! Thanks for taking the time to demonstrate a serious, but also entertaining use of the hp prime technology. This forum has a lot of content concerning bug issues, or limitations, but I find it very interesting when the finer points of using the product for real world problem solving get some show time! Very nice work! -Dale- |
