HP50g emulator?
11-19-2017, 09:34 PM
HP50g emulator?
hi,
is there a convenient (usable, maybe HP made...) emulator for HP50g in iOS? Thank you, Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-20-2017, 05:46 PM
RE: HP50g emulator?
I use an old version of Emu50g on an iOS 7 device. It runs perfectly, except that port 2 does not work, so I had to store my programs in port 1 and change some user key definitions. I am very satisfied with this app.
I've not found other 50g emulators for iOS. Jean-Charles |
11-20-2017, 05:52 PM
RE: HP50g emulator?
(11-20-2017 05:46 PM)Helix Wrote: I use an old version of Emu50g on an iOS 7 device. It runs perfectly, except that port 2 does not work, so I had to store my programs in port 1 and change some user key definitions. I am very satisfied with this app. Merci Jean-Charles! I'll see for it soon. I thought also HP had a such emulator, but maybe it is not in their planes at the moment. Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-20-2017, 07:36 PM
RE: HP50g emulator?
(11-20-2017 06:59 PM)moonbeam Wrote: m48/m48+ thank you. Have it a "realistic" skin like Emu50g? That of Emu50g is impressive: I've installed it in my iPad and it looks like my real HP 50g... Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-20-2017, 10:23 PM
(This post was last modified: 11-20-2017 10:44 PM by salvomic.)
RE: HP50g emulator?
(11-20-2017 09:42 PM)moonbeam Wrote:(11-20-2017 07:36 PM)salvomic Wrote: thank you. Have it a "realistic" skin like Emu50g? That of Emu50g is impressive: I've installed it in my iPad and it looks like my real HP 50g... thank you I'll try! Only a question: has m48+ a simple way to pass data between iOS (Cloud?) and the app, as Emu50g (via http)? I hope yes... EDIT: installed! you are right: they are very similar... also the server ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-21-2017, 08:17 AM
RE: HP50g emulator?
(11-21-2017 12:29 AM)moonbeam Wrote: Neither one is cloud-aware, both have a built-in http server. As far as I can tell, Emu50g is a clone of m48+. I wonder if anybody here knows more about the provenance of the respective apps. I agree. I tested a bit, yesterday and they are too similar, also the velocity. Only the HP50 skin has in the iPhone a row less in the display, both are better on the iPad and in iPad Pro both are a bit quicker. Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
