Reductions fractions.
11-28-2017, 11:31 AM
I would like find for example : Reduce this fractions to the same denominator 1/3 and 4/9. I calculate the lcm what it is 9 and I multiplication the 1/3 by 3. This me give 3/9. Then the answer is 3/9 and 4/9. Of course I know to do by hand but Well in the prime I know "comdenom" but this dont' give this answer and we have use arithmetic operator. For example SIMPLIFY (42/12,12/16,36/24) give [7/2 3/4 3/2], is it a command may be I am ignoring it, that give the same for fractions ? cmd(1/3,4/9)----->[3/9 4/9] cmd(5/9,7/4,6/11)----->[220/396 693/396 216/396] Thank. Gérard. |
11-28-2017, 02:18 PM
RE: Reductions fractions.
I'm not sure if there is such a command, but an alternative is to help with variables in the CAS.
Viga C | TD | FB |
11-28-2017, 02:23 PM
(This post was last modified: 11-28-2017 02:28 PM by DrD.)
With a list of fractions stored in LO:
Here's the equivalent numerators: EXECON("&1/gcd(L0)",L0); Each one times the common divisor: gcd(L0); -Dale- |
11-28-2017, 03:06 PM
Very helpfull ! Thank to you both. Gérard. |
11-28-2017, 03:38 PM
(11-28-2017 02:23 PM)DrD Wrote: Here's the equivalent numerators: Adapted Divisor: EVAL(1/gcd(exact(L0))) Numerator list: EXECON("&1/EVAL(gcd(exact(L0)))",L0) Viga C | TD | FB |
11-28-2017, 03:46 PM
Very helpfull ! Thank to you both. But surely I misunderstand with Carlos. Gérard. |
11-28-2017, 03:52 PM
The idea is to use variables that do not have assigned data, it is possible that in your calculator x, xx have a value, you can use other variables. I used those because they are the ones I can type faster.
Viga C | TD | FB |
11-28-2017, 04:12 PM
Thank once again it run with m, mm for example.
Gérard. |
11-28-2017, 04:56 PM
I appreciate Carlos and Dale for the elegant formulas and because I best understand some commands. Gérard. |
11-28-2017, 06:13 PM
RE: Reductions fractions. | |||
11-28-2017, 07:03 PM
I see a little thing I no understand, sometime there is decimal instead of integer. I give example in attachement. Even I try mani things it is no change. It is not important you know. Gérard. |
11-28-2017, 07:54 PM
(11-28-2017 06:13 PM)Didier Lachieze Wrote: For the numerator you can simply do: L0/EVAL(gcd(exact(L0))) Or even L0/gcd(exact(L0)) Prime, 15C CE |
11-28-2017, 09:47 PM
(This post was last modified: 11-28-2017 10:12 PM by StephenG1CMZ.)
(11-28-2017 07:03 PM)ggauny@live.fr Wrote: Hi, This gets rid of the unwanted real: Code:
Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
11-29-2017, 09:17 AM
(This post was last modified: 11-29-2017 09:21 AM by ggauny@live.fr.)
Taking the idea of Chromos for numerators and applying to denominator I obtain for example : LO[1/40 5/24 7/36 12/25]------->[1/40 5/24 7/36 12/25] LO/gcd(exact(LO))----->[45 375 350 864] //numerators 1/gcd(exact(LO))----->1800 //denominator commun This avoid the influence of *EVAL* wich give sometimes undesired decimals. Now I only have to find the good presentation like for example : 45/1800 375/1800 350/1800 864/1800 But this is a new challenge for me ! Thanks to all for help. Gérard. |
11-29-2017, 03:13 PM
(This post was last modified: 11-29-2017 07:18 PM by ggauny@live.fr.)
In CAS program I use this little code : Code:
In the CAS terminal we see [n, n1, n2......] the numerators and just below the denominator. Usefull to verify exercises of my greatgrandson wich learn fractions ! EDIT because little little boy is not good american, the right word is greatgrandson ! Gérard. |
11-29-2017, 03:35 PM
In Home program
Code: EXPORT RedFracssh(l) Viga C | TD | FB |
