pyILPER 1.6.0 and LIFUTILS 1.7.7 final release
11-28-2017, 06:37 PM
(This post was last modified: 12-03-2017 08:40 AM by jsi.)
pyILPER 1.6.0 and LIFUTILS 1.7.7 were just released on GitHub.
This release of pyILPER includes lots of enhancements, improvements and changes, see the release notes for details. pyILPER is available on the ANACONDA channel by now. A Code:
Windows users are strongly encouraged to do a reinstall of their Miniconda environment. Uninstall the old version first, download the most recent distribution of Miniconda (Python 3.6 version) for your 32/64 bit Windows. Run the installer and do not check the option to change the PATH environment variable. Proceed as documented in the installation instruction. The LIFUTILS got considerable internal changes, an installer for mac OS and new utilities to process HP-41 rom images. An important fix was applied to the textlif utility that adds implementation bytes that are needed by the HP-41. To use the LIFUTILS from pyILPER it is required to update to the 1.7.7. production version. See the installation instructions how to proceed. Regards Joachim |
11-28-2017, 11:27 PM
RE: pyILPER 1.6.0 and LIFUTILS 1.7.7 final release
Got them and installed fine. Thanks!
smp |
11-28-2017, 11:30 PM
(11-28-2017 06:37 PM)jsi Wrote: To use the LIFUTILS from pyILPER it is required to update to the 1.7.7. production version. See the installation instructions how to proceed. Thanks Joachim. For Windows, after reading the various install pages, I take it this is the proper overall sequence: 1. Uninstall old LIFUTILS 2. Install new LIFUTILS (using appropriate x32 or x64 setup program) 3. Use the "conda update --all" method (I assume this is the same even if I have miniConda installed) to update pyILPER client to 1.6.0 Pretty simple, looking forward to checking it. Had no time to try Beta, so eager to see this. Thanks again! --Bob Prosperi |
11-29-2017, 07:22 AM
(11-28-2017 11:30 PM)rprosperi Wrote: 1. Uninstall old LIFUTILS That's absolutely correct. This procedure applies for the other platforms as well. Anaconda or miniConda make no difference in this case. |
11-29-2017, 12:47 PM
(11-28-2017 06:37 PM)jsi Wrote: pyILPER 1.6.0 and LIFUTILS 1.7.7 were just released on GitHub. |
12-01-2017, 05:40 AM
The HP82162A printer emulation is super cool! Now I can print my programs and then pass the output to my Postscript printer. Ha-ha, for the first time in 36 years of using the HP-41, I can finally get real printer output with the right look at home!
Thanks a million! HÃ¥kan |
12-02-2017, 07:20 PM
Joachim (or anyone that knows):
For some reason, I can't seem to update pyILPer. I'm running Win-7 Pro (x64). I tried the "conda update --all" first. As it's been quite a while since I've updated, so conda selected many packages for update, which I approved. During the long (several minutes) update process the system displayed many (50-80?) warning messages, all the same: Code: WARNING conda.gateways.disk:exp_backoff_fn(47): Uncaught backoff with errno 41 but no actual errors, so once complete, I fired up ILPer only to see verison 1.4 was still installed and running. So I tried to update just pyilper again, and had this surprising result: Code: C:\Users\Prosperi\pyilper>conda update pyilper Any ideas why conda doesn't see the update? Should I run the update from a particular path? The installation instructions say Windows users should start pyilper from an Anaconda prompt. Is this different from a normal cmd shell? --Bob Prosperi |
12-02-2017, 08:11 PM
Indeed you did not update for a long time ;-). As of version 1.5 pyILPER moved to Python 3.6 and QT5. If a
Actual Miniconda Installers do not require to alter the Windows Path variable any more. Instead they install an Anaconda Promopt in the Windows start menu. If called it opens a console with the Miniconda environment set up properly. |
12-02-2017, 08:16 PM
(12-02-2017 08:11 PM)jsi Wrote: Since this will update every package in your Miniconda installation you may consider a clean new install of Miniconda instead. I, too, experienced issues with the latest version of Anaconda and had to reinstall. Then I figured out that I only needed to install Miniconda. For some reason I thought I also needed to install Anaconda. Dave |
12-02-2017, 08:37 PM
(12-02-2017 08:16 PM)Dave Frederickson Wrote:(12-02-2017 08:11 PM)jsi Wrote: Since this will update every package in your Miniconda installation you may consider a clean new install of Miniconda instead. Thanks Dave. Ripping out old version now.... Will holler when done. --Bob Prosperi |
12-02-2017, 08:41 PM
(12-02-2017 08:37 PM)rprosperi Wrote:(12-02-2017 08:16 PM)Dave Frederickson Wrote: I, too, experienced issues with the latest version of Anaconda and had to reinstall. Then I figured out that I only needed to install Miniconda. For some reason I thought I also needed to install Anaconda. You can create a shortcut to C:\Users\Me\Miniconda3\Scripts\pyilper.exe, change the Run behavior to Minimized, and have a quick method of launching the program, rather than using the Anaconda prompt. |
12-02-2017, 09:20 PM
(12-02-2017 08:41 PM)Dave Frederickson Wrote: You can create a shortcut to C:\Users\Me\Miniconda3\Scripts\pyilper.exe, change the Run behavior to Minimized, and have a quick method of launching the program, rather than using the Anaconda prompt. Great advice, upgrading to latest Miniconda (ripped out old, installed fresh) resolved it, everything is working. And this hint is perfectly timed, as my next task was precisely to find out how to do exactly this. I guess this somehow resolves all the needed environment settings wired into the Anaconda prompt? Thanks again! Oh, and Joachim - Excellent!! Excellent!! Excellent!! --Bob Prosperi |
12-02-2017, 11:03 PM
(12-02-2017 09:20 PM)rprosperi Wrote: I guess this somehow resolves all the needed environment settings wired into the Anaconda prompt? To be honest, I've always run pyILPER from the Windows Command Prompt without issue. It wasn't until recently that I learned of the Anaconda Prompt. Joachim? |
12-02-2017, 11:19 PM
(12-02-2017 11:03 PM)Dave Frederickson Wrote: To be honest, I've always run pyILPER from the Windows Command Prompt without issue. It wasn't until recently that I learned of the Anaconda Prompt. I'd guess that they created the Anaconda Prompt as a way to locally provide that task with all the proper paths and environment settings without having to 'dirty' the Windows global settings, as they can affect how other apps behave (which of course they shouldn't, but this is Windows). Also, on most managed domains, a user doesn't have the rights to make such changes, so this local approach solves that too. Anyhow, your suggestion works fine and I've got it set up, from a user's perspective, just the way it was and the way I like it (no need to have to interact with a manual command prompt). Thanks again, very timely replies made the whole thing quick and easy. --Bob Prosperi |
12-03-2017, 10:13 AM
Thank you for feedback. I updated the first post and added some additional information in the pyILPER Installation instructions concerning the difference between Anaconda and Miniconda.
02-04-2018, 05:38 AM
One of the new features of 1.6.0 is being able to copy from the printer window to the clipboard.
It seems that the text selected begins on the line above the cursor, not the line where the cursor is positioned. I also observed that the screen doesn't scroll when attempting to select text beyond what's displayed. Dave |
02-04-2018, 12:11 PM
Hi Dave,
(02-04-2018 05:38 AM)Dave Frederickson Wrote: It seems that the text selected begins on the line above the cursor, not the line where the cursor is positioned.in the upcoming version 1.7.0 of pyILPER which is due for beta release there are among other interesting features a lot of fixes of the selection feature. I just added a threshold to make the row selection behave less strict. I'd be very happy if you could test the latest commit of pyILPER on GitHub. See the "Installation of development versions" section of pyILPER installation instructions. Regards Joachim |
02-04-2018, 12:13 PM
RE: pyILPER 1.6.0 and LIFUTILS 1.7.7 final release | |||
02-04-2018, 05:15 PM
(02-04-2018 12:11 PM)jsi Wrote: Hi Dave, Joachim, The selection works nicely, now, and the selection scrolls past the bottom of the screen. Thanks. The scrolling, however, is rather slow. Is there a hot-key that can be pressed to select to the end of screen? Dave |
02-04-2018, 05:59 PM
User(s) browsing this thread: 5 Guest(s)
