(49G, 49g+ & 50g) DE: A Numeric to Symbolic Programme
12-03-2017, 11:35 AM
This thread
http://www.hpmuseum.org/forum/thread-9610.html
concerning accuracy prompted this posting.
The programme DE & 9 associated sub-programmes are updates for the 49G, 49g+ & 50g of the programme DE from
Ralf Thoma's
book
HP-Taschenrechner
Programmieren mit RPL
ISBN 3-88229-052-8
from 1995 & originally for the 48G.
DE takes real or complex numerical input & seeks a simple symbolic representation of the number, returning the input in the variable DE.OR, error in the symbolic representation in variable DE.ER & the symbolic representation to the stack. The programme also accepts a list of numbers.
Examples:
for input
(.701560760018,.129436325678)
the programme returns
'3*√7/(8*√2)+i*(62/479)'
& similarly
(1.60943791243,.261799387799)
'LN(5)+i*(1/12*π)'
(.629960524948,25.2477084857)
'(1/4)^(1/3)+i*(7*√13+1/113)'
The programme warns of a poor approximation & prefers symbolics containing small value integers.
I welcome improvements & am most pleased to hear of bugs.
DE
  CK1
  FPTR2 ^PUSHFLAGS_
  BINT22
  SetSysFlag
  BINT103
  SetSysFlag
  BINT105
  SetSysFlag
  ID x001
  FPTR2 ^POPFLAGS_
x001
  DUP'
  ID DE.OR
  ?STO_HERE
  ID x003
  DUP
  ID DE.OR
  ID x002
  ID DE.ER
  ?STO_HERE
  FPTR2 ^QPI
x002
  DUPTYPELIST?
  case
    ID x002
    BINT2
    FALSE
    ROMPTR E8 10
  x-
  xABS
  CRUNCH
  DUP
  % .00000000001
  ?SEMI
  " DE DANGER: RESULT NOT ACCURATE!"
  DispCoord1
  SetDA3Temp
x003
  DUPTYPELIST?
  case
    ID x003
    BINT1
    FALSE
    ROMPTR E8 10
  DUPTYPEREAL?
  case
  ID x006
  DUPTYPECMP?
  NOT?SEMI
  C%>%
  ID x006
  SWAP
  ID x006
  SWAP'
  xi
  SWAP'
  x*
  BINT3
  SYMBN
  x+
x004
  DUP
  %SGN
  SWAP
  %ABS
  ID x008
  ROT
  SWAPDUP
  %1
  caseDROP
  x/
  BINT3
  SYMBN
x005
  SWAP
  CRUNCH
  %SQ_
  ID x008
  %EXPONENT
  SWAP
  %EXPONENT
  %ABS
  %5
  IT
    BINT6
    TestUserFlag
    ?SEMI
    EVAL
    SWAPROT
    BINT6
    SetUserFlag
  DROP
x006
  CRUNCH
  DUP%0=
  ?SEMI
  DUP
  ID x004
  editdecomp$w
  LEN$
  BINT14
  NOTcase
  ID x004
  DUP
  xSQ
  ID x004
  editdecomp$w
  LEN$
  BINT14
  NOTcase
  ID x009
  BINT6
  ClrUserFlag
  DUP
  %SGN
  SWAP
  %ABS
  DUP
  %LN
    %LN
    xEXP
    ID x007
  ID x005
  DUP
  %EXP
    %EXP
    xLN
    ID x007
  ID x005
  DUP
  %PI
    %PI
    ID x006
    xPI
    x/
    OVER
  ID x005
  DUP
  %PI
    %PI
    ID x006
    xPI
    x*
    OVER
  ID x005
  DUP
  %PI
  xSQ
    %PI
    xSQ
    ID x006
    xPI
    xSQ
    x*
    OVER
  ID x005
  DUP
  %ALOG
    %ALOG
    xLOG
    ID x007
  ID x005
  x*
  %0
  % .25
  2DUP
  %1/
    %1/
    2DUP
    ID x006
    OVER
    ID x006
    x+
  ID x005
  2DUP
  %1/
    %1/
    2DUP
    ID x006
    OVER
    ID x006
    x-
  ID x005
  2DUP
  %SQRT
    %SQRT
    2DUP
    ID x006
    OVER
    ID x006
    x+
  ID x005
  2DUP
  %SQRT
    %SQRT
    2DUP
    ID x006
    OVER
    ID x006
    x-
  ID x005
  DUP
  %10
  BINT6
  TestUserFlag
  OR
  UNTIL
  DROP
  %1
  %1+
  2DUP
  %SQRT
  %MOD
    %SQRT
    2DUP
    %MOD
    ROTOVER
    ID x006
    OVER
    ID x006
    x+
  ID x005
  2DUP
  %SQRT
  DUPUNROT
  %MOD
    %SQRT
    2DUP
    %MOD
    %MOD
    2DUP
    ID x006
    OVER
    ID x006
    x-
  ID x005
  DUP
  %16
  BINT6
  TestUserFlag
  OR
  UNTIL
  DROP
  %0
  DUP
  %10
  BINT6
  TestUserFlag
  NOTAND
  WHILE
    % .25
    2DUP
      2DUP
      ID x006
      OVER
      ID x006
      x+
    ID x005
    2DUP
      2DUP
      ID x006
      OVER
      ID x006
      x-
    ID x005
    2DUP
    %1/
    %SQRT
      %1/
      %SQRT
      2DUP
      ID x006
      OVER
      ID x006
      x+
    ID x005
    2DUP
    %1/
    %SQRT
      %1/
      %SQRT
      2DUP
      ID x006
      OVER
      ID x006
      x-
    ID x005
  REPEAT
  DROPDUP
  %ABS
  BINT6
  BINT2
  DO
  DUPINDEX@
  FPTR2 ^PPow#
    OVER
    %SGN
    OVER
    INDEX@
    FPTR2 ^PPow#
    ID x006
    INDEX@
    UNCOERCE
    %1/
    ID x006
    x^
    x*
  ID x005
  LOOP
  DROP
x007
  SWAP
  ID x006
  SWAP
  BINT2
  SYMBN
  OVER
x008
  %9
  OVER
  %EXPONENT
  %1
  %MAX
  %ALOG
  DUPUNROT
  2DUP
  OVER
  %MOD
  DUPUNROT
  % 50.
  UNTIL
  SWAPDROP
  ROTOVER
  %IP
  3UNROLL
  %IP
x009
  DUP
  %SGN
  SWAP
  %SQ_
  ID x008
  BINT2
  ZERO_DO
  % 49.
  OVER
  %SQRT
  %IP
  %MIN
  %1
  %MAX
  2DUP
  %SQ_
  %MOD
  %0<>
  OVER
  %2
  AND
  WHILE
  %1-
  REPEAT
  DUPUNROT
  %SQ_
  DUP
  %1
  ITE
  DROP
    xSQRT
    BINT2
    SYMBN
    x*
  SWAPLOOP
  SWAP
  x/
  x*
