HP45 doesnˋt work on batteries
12-03-2017, 06:40 PM (This post was last modified: 12-04-2017 02:45 PM by Matthias D..)
Hi there,
My HP45 does work with the adapter plugged in, but doesnˋt work with batteries.
Battery-pack is o.k., works with other calculators.
What could be broken?
Thanks!
Calculator works again. It was the short clip in the charger slot. It didnˋt make contact from left to right pin.
12-03-2017, 08:09 PM (This post was last modified: 12-03-2017 08:20 PM by BobVA.)
RE: HP45 doesnˋt work on batteries
There's a leaf-type switch that's part of the ac adapter socket on the calculator that may not be working properly. This article might be helpful.
And some excellent pictures and discussion in in this article by Geoff.
