Downgrade - is it safe?
12-19-2017, 06:37 PM
Is it safe to downgrade the firmware to very old version (v8151)? I want to perform performance tests of HPPPL code execution with old firmware and take measurements. Piotr Kowalewski |
12-20-2017, 01:44 AM
RE: Downgrade - is it safe?
Yes, it is. Just be aware that you can't move data files backwards in general so they may be lost.
Upgrading on the Mac does require being up to a certain level of firmware as well, so if that is your main platform be aware you'll need a windows machine. TW Although I work for HP, the views and opinions I post here are my own. |
12-20-2017, 11:34 AM
OK, I will do hard reset before downgrade and use windows machine.
Thank you, Tim. Piotr Kowalewski |
