EMU48: external lcd new cmd
12-22-2017, 01:50 PM
Hello CG
To recover some skins designed for pocketpc, please can add a new command (External INTEGER) that is to visualize the LCD outside the keyboard, in this way you can have the keyboard separated from the screen, this I have also seen in other emulators.
PHP Code:
Lcd
    Zoom INTEGER
    Zoomxy INTEGER INTEGER
    Vertical INTEGER
    Offset INTEGER INTEGER
        External INTEGER
    Bitmap STRING
    Color INTEGER INTEGER INTEGER INTEGER
End
Thanks
