Best Battery Charger
01-12-2018, 04:02 PM
I've been using this battery charger successfully with my Enerloops for 8 years. It is now discontinued and I'd like to buy another, modern version similar to this.
Any suggestions?
Thanks
.....Art
https://www.amazon.com/gp/product/B00077...UTF8&psc=1
01-12-2018, 04:07 PM
RE: Best Battery Charger
(01-12-2018 04:02 PM)larthurl Wrote:  I've been using this battery charger successfully with my Enerloops for 8 years. It is now discontinued and I'd like to buy another, modern version similar to this.
Any suggestions?
Thanks
.....Art
Many of us here use the BC-700, from the same mfr. I am not aware of the specific differences (after reading specs, perhaps you could easily see).
https://www.amazon.com/Crosse-Technology-BC-700-Battery-Charger/dp/B000RSOV50
01-12-2018, 04:09 PM (This post was last modified: 01-12-2018 04:10 PM by Massimo Gnerucci.)
Any suggestions?
Thanks
.....Art
This is the usual recommendation.
Edit: Bob beat me... Smile
Greetings,
    Massimo
01-12-2018, 04:22 PM
(01-12-2018 04:07 PM)rprosperi Wrote:  Many of us here use the BC-700, from the same mfr. https://www.amazon.com/Crosse-Technology-BC-700-Battery-Charger/dp/B000RSOV50
Yes, that's the one recommended to me a couple of years ago. I got it and it works like a charm.
smp
01-12-2018, 04:31 PM
I too have the BC-700, it's a nice charger, lots of functionality.
Software Failure: Guru Meditation
Antonio
IU2KIY
01-12-2018, 04:54 PM
Thanks everyone. Looks like the BC-700 is the answer.
I was thinking of this one as the "1000" model comes with standard batteries that I don't need or want.
.....Art
01-12-2018, 05:12 PM
If I understand correctly, the difference between the 700 and the 1000 should be the maximum charging current of 700 mA vs 1800 mA.
I don't want my batteries to overheat, so I almost always run the charger at its minimum 200 mA and let them charge over night. If I need a really quick charge for some reason, I have a second charger which delivers 1 A, but I never actually used it for this purpose, I only use it to charge my 18650 Lithium cells.
Antonio
IU2KIY
01-12-2018, 05:28 PM
(01-12-2018 04:02 PM)larthurl Wrote:  Any suggestions?
IMHO, Powerex MH-C9000 charger is the best choice. For example it practically doesn't heat the Low Self-Discharge AA batteries with default charge current of 1 Ampere compared to La Crosse.
01-12-2018, 07:33 PM
I'm a very recent purchaser of a BC-700 and Eneloop batteries and I am very happy with both. Also got the Classic series battery carrier that holds 3 standard AAA batteries from TAS and am happy with that as well.
Try CC41!
01-12-2018, 07:56 PM
(01-12-2018 07:33 PM)Craig Bladow Wrote:  I'm a very recent purchaser of a BC-700 and Eneloop batteries and I am very happy with both. Also got the Classic series battery carrier that holds 3 standard AAA batteries from TAS and am happy with that as well.
got the AAA classic battery holder - agree pretty neat.
BC-700 on order - arriving Sunday (Amazon Prime of course)
