Online HP-45 Emulator - First calculator with a shift key
12-28-2023, 06:15 PM
(This post was last modified: 12-28-2023 06:33 PM by van2z.)
After building the HP-35 calculator, I was looking if there was any low hanging fruit for me to reuse the same code. I found the HP-80 used exactly the same hardware, but I couldn't find the ROM.
I see Brouhaha seems to have manually copied each assembly instruction from the original patent into his Nonpareil code, but I don't have an easy way to compile that to see the ROM binary. If anyone can do this, it would be appreciated. Moving on after the HP-80, was the HP-45, for which I was able to find the ROM binary, also from Brouhaha, here. The hardware here was also very similar. The main difference is the inclusion of a "data storage" chip, giving the calculator an extra 560 bits to use. Here it is: https://veniamin-ilmer.github.io/hp45/ I have never used this calculator before. I see it starts out using fixed notation 2. If anyone has used this calculator before, please let me know if it is functioning properly, or if you see any issues. |
12-28-2023, 07:22 PM
(This post was last modified: 12-28-2023 07:51 PM by Thomas Klemm.)
RE: Online HP-45 Emulator - First calculator with a shift key
(12-28-2023 06:15 PM)van2z Wrote: I found the HP-80 used exactly the same hardware, but I couldn't find the ROM. You may have to build the nonpareil project and use uasm to compile 80.asm into an object file. You can find here the: 70.rom. This is another calculator that used the same chip. From HP-45: Quote:The timer could be invoked by pressing RCL and then pressing CHS 7 8 all at the same time. Not sure if this is possible, but it would be cool if the timer could be started. Addendum: If found them here: ROMs Relevant: HP-80 Nonpareil Emulator: fixed a bug in the calendar functions IIRC the bug was present in his iPhone app. Thus you might have to apply the patch. |
12-28-2023, 08:02 PM
Thank you Thomas for the ROMs! I will be looking into them a bit later.
After a bit of searching, I found these simultaneous key presses trigger as if pressing a nonexistent key code 60. Although this does switch it into timer mode, it seems buggy. It doesn't seem to work correctly. I am trying to figure out if this is an issue in the emulator or the ROM. I have to go right now. I don't want to leave you hanging, so I added a button at the bottom to trigger the timer mode. You still have to press RCL before pressing the timer button to get it to switch modes. |
12-28-2023, 10:23 PM
This Timer feature has revealed a few issues in my emulation, which is great.
I fixed a lacking decimal issue. Tomorrow I'll tackle the sticky keys and blinking display. The timer works, but for now you just might need to click buttons a few more times to get them to work. (CHS is start / stop. CLX clears the count). |
12-28-2023, 10:40 PM
(12-28-2023 10:23 PM)van2z Wrote: This Timer feature has revealed a few issues in my emulation, which is great. Note that the 45 lacked a crystal for the timer so it was very inaccurate unless you opened it up and installed the correct crystal yourself. Tom L Cui bono? |
12-28-2023, 11:14 PM
(This post was last modified: 12-28-2023 11:16 PM by van2z.)
I do like that the timer seems relatively accurate. This shows me the emulator is getting timing the CPU instructions accurately. I'll look into adding a crystal when emulating the HP-55.
12-29-2023, 07:51 AM
(This post was last modified: 12-29-2023 07:57 AM by Namir.)
I noticed a bug in the HP45 enulator. The RCL 0 does not work.
Also when you do CHS and the value in the X register is 0, the emulator should ignore the CHS command. Namir |
12-29-2023, 08:15 AM
(12-29-2023 07:51 AM)Namir Wrote: Also when you do CHS and the value in the X register is 0, the emulator should ignore the CHS command. I'm not sure but this might be due to HP-45 revisions. My simulator shows a negative sign when 0.00 is displayed, and also a real HP-45 that I have here (serial 1349S 11201) cheers Tony |
12-29-2023, 10:43 AM
(12-29-2023 08:15 AM)teenix Wrote: My simulator shows a negative sign when 0.00 is displayed, and also a real HP-45 that I have here (serial 1349S 11201) Here's another HP-45 Emulator that shows the same behaviour. |
12-29-2023, 11:57 AM
You guys are right. The minus zero is part of the hp-45.
12-29-2023, 01:11 PM
(12-28-2023 07:22 PM)Thomas Klemm Wrote: Thus you might have to apply the patch. That's already done. The commit message of 4217291 from Jul 4, 2014 is: Quote:Patch to HP-80 ROM, which solves DATE function bug. Patch provided by… |
12-29-2023, 05:22 PM
Hey folks, I fixed up the sticky keys and display issues. The timer works great now.
This also fixes an issue I missed earlier with mobile users getting a delayed touch response. This has been resolved for both HP-35 and HP-45 emulators. Happy new years everyone. See you next year. |
User(s) browsing this thread:
