New Version: 2.0.0.13865 (2018 07 06)
07-21-2018, 07:24 AM
RE: New Version: 2.0.0.13865 (2018 07 06)
(07-21-2018 05:13 AM)harryp Wrote:  My Connectivity Kit and Calc updated but the Prime Virtual Calculator won't connect. I got to the FTP site, which do I use for Win 10, the .exe or the .dmg and do I just run the .exe?
.dmg is for Mac.
FTP through firewalls / NAT routers can be tricky as the FTP protocol requires special handling by the firewall / router. Also FTP can work in "active mode" or "passive mode". Depending on your firewall / router, 0, 1 or 2 of these modes may work properly. I don't know which mode the Prime Virtual Calculator uses, if any.
— Ian Abbott
07-21-2018, 07:50 AM
It uses HTTP for all connections. No FTP protocol is in use anymore.
TW
07-21-2018, 07:14 PM
Is there going to be an update of the HP Prime Pro app on Android to go with this new version?
07-22-2018, 01:33 AM
(07-21-2018 07:14 PM)grsbanks Wrote:  Is there going to be an update of the HP Prime Pro app on Android to go with this new version?
I am wondering about it, too. I have bought HP Prime Pro app for Android and I haven't seen any update. I believe the update will be released in the future.
07-22-2018, 02:24 AM
(11-08-2017 06:28 PM)Tim Wessman Wrote:  There are significant changes to INPUT planned but they did not make it in time for this release.
Hello Mr. Tim Wessman, can we still expect more planned developments with INPUT besides INPUT(EVAL(List))?
Viga C | TD | FB
07-22-2018, 06:55 AM
Thanks for the help, everything got updated alright.
09-24-2018, 02:25 AM
I just bought my calculator Wednesday September 19th, 2018 and have received it yesterday. Since using it, the touch screen has not worked. I have looked at other forums and have tried all the procedures. None of them have fixed the problem. Any possible solutions will be helpful. I can also not find any assistance at the hp website.
09-24-2018, 09:24 AM
(09-24-2018 02:25 AM)hollywoodrono Wrote:  I just bought my calculator Wednesday September 19th, 2018 and have received it yesterday. Since using it, the touch screen has not worked. I have looked at other forums and have tried all the procedures. None of them have fixed the problem. Any possible solutions will be helpful. I can also not find any assistance at the hp website.
Sounds like a hardware fault to me (possibly a disconnected touch screen connector?).
— Ian Abbott
09-24-2018, 12:38 PM
If the calculator is new, I would say that your best bet is to use the waranty...
Now, it is possible that the only problem is that the little connector from the PCB to the touch controler disconnected... Easy to fix... But fixing it would require opening the calculator... Which in theory voids the waranty :-(
Cyrille
