For Sale HP-97 Test-Bench
04-17-2014, 09:42 AM
A near complete HP-97 Test-Bench with all the chip socketed. Lack of thermal printer head. For sale at best offer.
Ignazio ______________________________________ RPN...What else! |
04-18-2014, 04:06 AM
RE: For Sale HP-97 Test-Bench
Does the card reader work? Any keys lack the expected key snap? Do all the LED segments work fine?
Thanks, Namir |
04-18-2014, 06:38 AM
(This post was last modified: 04-18-2014 06:39 AM by ignazio.)
Hi Namir,
the following are the calculator conditions. - Keyboard: ok - Display: ok - Card reader: ok - Logic: ok ( new bugless ROM 550/551) - Printer: ok but with some thermal resistors bad and lack of the tear bar - Case: complete with battery door and latches - All the chip in main board socketed - Cathode driver and 2 anode driver socketed - card reader sense apmplifier socketed - all chip in printer PCB socketed Thanks for your interest. regards Ignazio |
04-28-2014, 03:34 PM
Maybe some images my help you selling the test bench.
04-28-2014, 07:27 PM
(This post was last modified: 04-28-2014 07:29 PM by ignazio.)
our friend is right, so I've added some image of the calculator. This is the first lot of pictures: [attachment=596][attachment=595][attachment=594][attachment=597][attachment=598] |
04-28-2014, 07:31 PM
... and this is the final lot:
Ignazio [attachment=599][attachment=600][attachment=601][attachment=602] |
04-28-2014, 07:51 PM
Please forgive me, but what's the difference to a usual HP-97 calculator? Why do you call it a 'HP-97 Test-Bench'? TIA for enlightenment.
d:-? |
04-28-2014, 08:16 PM
RE: For Sale HP-97 Test-Bench | |||
04-28-2014, 08:21 PM
(This post was last modified: 04-28-2014 08:28 PM by Thomas Klemm.)
(04-28-2014 07:51 PM)walter b Wrote: Please forgive me, but what's the difference to a usual HP-97 calculator? (04-18-2014 06:38 AM)ignazio Wrote: - All the chip in main board socketed Compare these images: Cheers Thomas |
04-29-2014, 08:58 AM
(This post was last modified: 04-29-2014 09:00 AM by ignazio.)
(04-28-2014 07:51 PM)walter b Wrote: Please forgive me, but what's the difference to a usual HP-97 calculator? Why do you call it a 'HP-97 Test-Bench'? TIA for enlightenment. Thanks for the reply posted by Thomas and Sylvain. Walter, the only valid reason to install the sockets for all the chip in a calculator, is to permit at the owner to test all the component without stress the PCB and the chip with too much heat from the solder iron, but primarily is to test the components on a machine certainly functional. In this HP-97, you can test: ACT (1820-1596) from: HP 21,22,25,25C 29C,19C,67,91,92,95C,97 AND 97S; ACT (1820-1952) from: HP 19C, 97,97S; CRC (1820-1751) from: HP 67, 97,97S; PIK (1820-1680) from: HP 19C, 97,97S; CATHODE DRIVER (1820-1629) from: HP 19C, 91, 92, 95C, 97 and 97S; RAM/ROM (1818-0226, 1818-0228, 1818-0550,1818-0551) from HP 67,97,97S; MOTOR SPEED CNTRL (1810-0236) from: HP 10A,19C,91,92,95C,97 and 97S. SENSE AMPL. (1826-0322) from: HP 67, 97, 97S and HP-82104A (HP-41 CR) I believe that may be useful, or not? Regards Ignazio |
05-03-2014, 04:36 PM
(This post was last modified: 05-03-2014 04:37 PM by aurelio.)
(04-29-2014 08:58 AM)ignazio Wrote:(04-28-2014 07:51 PM)walter b Wrote: Please forgive me, but what's the difference to a usual HP-97 calculator? Why do you call it a 'HP-97 Test-Bench'? TIA for enlightenment. We apreciated your job no far in time here and I renew my compliments for brilliant idea |
05-03-2014, 05:00 PM
I also have a 97 with all the chips on the main board socketed it was very helpful in troubleshooting a 67, it allowed me to isolate the failure down to one of two ROMs, and I also used it to verify the chips in a 97 I repaired for another gentleman recently. While testing the chips for the 97 I also verified that the PIK in my test 97 is indeed flakey, it does not print properly until the calculator has been on for about 10 mins.
05-09-2014, 06:43 AM
RE: For Sale HP-97 Test-Bench - SOLD
thanks a lot for the interest but I've just sold the calculator. Ignazio ______________________________________ RPN...What else! |
