Need help for some HP Prime calculus/functions
12-22-2019, 11:53 PM
RE: Need help for some HP Prime calculus/functions
(12-22-2019 09:49 PM)CyberAngel Wrote:
(12-22-2019 07:47 PM)toml_12953 Wrote:  All of my Primes (HW A, two HW C (old and new keyboard) and D) had Trig Explorer 2 and 3 on them. I deleted all of them. Am I the only one who ended up with multiple Explorers?
Yes, yes you are--- ;-)
Good! I feel so special! Big Grin
Tom L
Cui bono?
12-23-2019, 10:06 AM
(12-22-2019 07:36 PM)Devil69 Wrote:  Hi Nigel thank you very much I followed your instructions and it finally worked!
I think HP should add the variable "k" for trig (in)equations in their future update to do these operations without assume() function so that the answer looks like this:
x>π/6+2kπ and x<5π/6+2kπ, k∈ℤ
Glad to help. I agree with you about including an integer in the solution. The strange thing is that the Prime already does this when solving trigonometric equations: try solving \(\sin(x)=\frac12\), with "Principal" unticked in the CAS settings. So the mechanism is there, but for some reason it isn't applied to inequalities.
Nigel (UK)
12-23-2019, 09:30 PM
Nigel (UK)
After unticking Pricipal in CAS settings and trying to solve \(\sin(x)=\frac12\), I have this result:
(12*n_24*π+π)/6, (12*n_24*π+5*π)/6, what does mean 12*n_24*π ?
Thanks
12-24-2019, 07:30 AM
12*k*pi Wink
Best,
Aries Smile
12-24-2019, 12:03 PM
(12-23-2019 09:30 PM)Devil69 Wrote:
(12-23-2019 10:06 AM)Nigel (UK) Wrote:  Glad to help. I agree with you about including an integer in the solution. The strange thing is that the Prime already does this when solving trigonometric equations: try solving \(\sin(x)=\frac12\), with "Principal" unticked in the CAS settings. So the mechanism is there, but for some reason it isn't applied to inequalities.
Nigel (UK)
Thanks
n_24 is an arbitrary integer. If you run the command again you should get n_25 in the answer, and so on. This is better than using n or c or k, as these are common variable names which might already be in use elsewhere.
Nigel (UK)
12-24-2019, 03:53 PM
(12-24-2019 07:30 AM)Aries Wrote:  12*k*pi Wink
Best,
Aries Smile
Quote: n_24 is an arbitrary integer. If you run the command again you should get n_25 in the answer, and so on. This is better than using n or c or k, as these are common variable names which might already be in use elsewhere.
Alright then thanks for your help guys and have a nice Xmas Eve!
12-25-2019, 08:38 AM
Best,
Aries Smile
Happy XMas to you too and everyone ! Wink
Best,
Aries Smile
