New G2 Firmware 20200116 - Problems - FIXED w/ 20200121
01-22-2020, 09:35 PM
Post: #101
RE: New G2 Firmware 20200116 - Problems
I just installed the 2020 01 21 Firmware from my Mac:
Software Version: 2.1.14433 (2020 01 21)
Hardware Version: D
CAS Version: 1.5.0
Serial Number: 9CJ8...
Operating System: V2.060.650
Thanks very much to all the folks who provided assistance and advice here, and also to all the folks at HP who quickly fixed this firmware after the issue was reported.
smp
01-22-2020, 10:54 PM
Post: #102
My G2 now works! Thanks to everyone!
01-23-2020, 04:53 AM
Post: #103
Thank you for everyone that helped check this. I've resumed the process of officially releasing the files out... now on to bigger and (hopefully) better things since this minor maintenance release is out the door.
TW
01-23-2020, 04:55 AM
Post: #104
Updated G2 to 20200121, seems to be working just fine now, Thanks for the quick fix.
01-23-2020, 06:12 AM
Post: #105
Thanks to all of you who helped find and correct the touch driver issue!
Cyrille
01-23-2020, 07:58 AM
Post: #106
I found some problems, but not of the latest version, they are mostly things that are dragged from past versions, I will take the time to document it, the day I was going to report it they launched the 2020 01 16 and it took me away.
Viga C | TD | FB
01-23-2020, 09:15 AM
Post: #107
Hooray, touchscreen works on my G2 again.
Note:
On hpcalc.org the G2 firmware still shows the old update code of 20200116, select it and download the new 20200121 zip file.
HP Prime team; thank you !!
— Dirk Hartland
01-23-2020, 01:02 PM
Post: #108
The 2020 01 21 firmware has solved the touch screen issue on my G2. I don't know if this is the place to mention it, but the issue which I reported several times still hasn't been solved. If I install the control systems app and the calculator reboots, it crashes and clears the entire memory. This means the only way I can use this app is to never turn the calculator completely off or hope nothing crashes the calculator, forcing a reboot.
01-23-2020, 02:54 PM
Post: #109
14433... … … Where's the file?
01-23-2020, 03:48 PM
Post: #110
Hello Christóbal,
Go to hpcalc.org.
At the bottom (almost) it says
"Updated HP Prime G2 Firmware to 2.1.14425 (2020-01-16) on PC".
Select this and you will see
https://www.hpcalc.org/prime/pc/HP_Prime...200121.zip
Download this and unzip this.
How to proceed is given several times in the forum.
— Dirk Hartland
01-23-2020, 05:17 PM
Post: #111
(01-23-2020 03:48 PM)Dirk.nl Wrote:  Hello Christóbal,
Go to hpcalc.org.
Thanks, quite touchy now...
01-23-2020, 05:24 PM
Post: #112
Okay, Christóbal !
— Dirk Hartland
01-23-2020, 06:04 PM
Post: #113
Great !!!
Thanks a lot
jp
01-24-2020, 03:14 AM
Post: #114
(01-22-2020 03:07 AM)Mark Hardman Wrote:
(01-22-2020 02:55 AM)Eddie W. Shore Wrote:  Doing the On + symb just flashes the screen for me - no numbers. Not sure if I'm doing it right. But I now notice a short "load" time of the screen when I turn on the Prime.
The touch screen on my G2 is still working properly after updating it a few days ago.
Eddie, you need to press and hold On + Symb and then release the On key while keeping Symb pressed until the calculator switches to Update Mode (3-4 seconds).
I have 3 2
Thanks.
01-24-2020, 12:13 PM (This post was last modified: 01-24-2020 01:21 PM by rombva.)
Post: #115
There is an additional issue on G2 besides a touch screen work problem. It still remains after the last update.
After installing the 20200121 FW my Prime G2 demonstrates a strange behavior after soft rebooting [ON]&[Symb].
1) Turn power off and than turn power on.
2) After the first reboot on the Prime's screen continuosly the HP logo appears.
3) After the second reboot all the Prime's memory seems to be lost, nothing appears in the mem manager.
4) After the third reboot all progrms restore in the Prime's memory (all notes are loosing).
Repeated rebooting shows the same sequence 1) - 4).
P.S. After installing new FW all data remain on calc.
01-24-2020, 12:19 PM
Post: #116
(01-24-2020 12:13 PM)rombva Wrote:  After installing the 20200121 FW my Prime G2 demonstrates a strange behavior after soft rebooting [ON]&[Symb].
Not here. Just tried this on my G2 and it works as expected.
There are only 10 types of people in this world. Those who understand binary and those who don't.
01-24-2020, 01:40 PM (This post was last modified: 01-24-2020 01:41 PM by rombva.)
Post: #117
I'm happy for your sake. But I have this problem with my G2.
01-24-2020, 01:57 PM
Post: #118
(01-24-2020 01:40 PM)rombva Wrote:  I'm happy for your sake. But I have this problem with my G2.
Precisely. It's not with the firmware (if it was, my Prime would exhibit the same behaviour, as would everyone else's), it's with your Prime.
The only thing you can do is reformat the C: drive and try your test again. If it still misbehaves then your Prime is faulty. If not, then keep adding your programs one by one and repeating the test until the Prime fails again. When it does fail, it's the program that you added last that is most likely the cause of the problem.
01-24-2020, 04:48 PM (This post was last modified: 01-24-2020 05:04 PM by TheLastMillennial.)
Post: #119
Hey my G2's touch screen still doesn't work on the latest 2.1.14425 (2020 01 20)! Sad
When I go to the update mode, I have 3 3 in the top left.
My recovery screen info is:
data Version: V14424
OS Version: 2.1
PCB Version: D
Touch IC FW Ver: ilitek-00
EDIT:
Rolling back to 20191120 fixes the display and changes the Touch IC FW Ver to GT5688-516
Cemetech | YouTube
01-24-2020, 05:08 PM
Post: #120
(01-24-2020 04:48 PM)TheLastMillennial Wrote:  2020 01 20
You need 20200121.
