hp41 flying goose, program execution indicator
06-01-2014, 10:07 PM
Is there a way to 'reactivate' the flying goose after displaying the ALPHA register.
I have output that persists on the screen for quite a while and it misleads you into thinking the program has locked up. Is there any way to flick the execution indicator back on?
Todd
06-01-2014, 11:47 PM
RE: hp41 flying goose, program execution indicator
(06-01-2014 10:07 PM)twdeckard Wrote:  Is there a way to 'reactivate' the flying goose after displaying the ALPHA register?
CLD is the word you're looking for:-)
HTH
-- Ray
06-02-2014, 01:18 AM
(06-01-2014 11:47 PM)Raymond Del Tondo Wrote:  CLD is the word you're looking for:-)
HTH
Excellent - thanks! That is it exactly.
06-02-2014, 01:46 PM
You are a real hero if you can make it the goose fly backwards ![/b]
Regards, Meindert
06-02-2014, 02:01 PM
(06-02-2014 01:46 PM)MeindertKuipers Wrote:  You are a real hero if you can make it the goose fly backwards ![/b]
IIRC, eleven labels in a row has that effect, because the goose moves forward 11 spaces so quickly that it appears to have flown backwards one space.
A backwards FACING goose is more difficult, but doable.
<0|ɸ|0>
-Joe-
06-02-2014, 02:14 PM
Just my usual blast from the past... :)
06-03-2014, 02:15 AM
(06-02-2014 02:14 PM)Massimo Gnerucci Wrote:  Just my usual blast from the past... Smile
That thread mentions "goose droppings". Some can be seen here: http://hhuc.us/2009/index.htm
Check out other pages in that HHC 2009 website for some other fun HP-41 "screen captures", some of which are animated. Only the real HP-41 addicts will recognize all of them.
<0|ɸ|0>
-Joe-
06-03-2014, 05:12 AM
(06-02-2014 02:01 PM)Joe Horn Wrote:  A backwards FACING goose is more difficult, but doable.
And a backwards facing goose flying backwards is the second derivative, so to speak ;-)
There are two functions in the "Sudoku & Sound" module that allow for these without any synthetics wizardry: "LEFT" and "GOOSE" - simply intersperse them in the FOCAL code and voila, your goose obeys your commands...
I got those from the NFC EPROM, written by Nelson C. Crowle - remember the AECROM?
See page 9 in the attached doc.
Attached File(s)
.pdf  Sudoku write-up.pdf (Size: 547.34 KB / Downloads: 17)
06-03-2014, 05:42 AM
Whoa! A real Goose-fest... Smile
Thank you Joe
06-03-2014, 05:50 AM
(06-03-2014 05:42 AM)Massimo Gnerucci Wrote:  Whoa! A real Goose-fest... Smile
Thank you Joe
as good as a goose feast ! ;-)
06-03-2014, 06:08 AM
Thank you Joe
Gotcha! What about a goose-festival? Big Grin
