(41) JETLOG Program
12-15-2020, 06:06 AM (This post was last modified: 02-20-2022 05:05 AM by WrongWay.)
(41) JETLOG Program
This was a program my father wrote, it appears to be a flight planning application. I could use some help deciphering it. It does run. Run size and set to 100 to fully load the program
2022/02/19
corrected the original program and attached it to this post
Attached File(s)
.txt  JETLOG.txt (Size: 3.78 KB / Downloads: 23)
12-15-2020, 05:23 PM
RE: JETLOG Program
Sounds like a project for Geoff Quickfall Smile
12-15-2020, 06:44 PM (This post was last modified: 12-15-2020 06:44 PM by WrongWay.)
RE: JETLOG Program
I wasn't sure if it belonged in the software library as it lacks documentation. Any help in deciphering what is going on is greatly appreciated
12-15-2020, 06:48 PM
RE: JETLOG Program
Set Size to 100
05-13-2021, 07:13 AM (This post was last modified: 05-13-2021 07:16 AM by Ángel Martin.)
RE: (41) JETLOG Program
(12-15-2020 06:06 AM)WrongWay Wrote:  This was a program my father wrote, it appears to be a flight planning application. I could use some help deciphering it. It does run. Run size and set to 100 to fully load the program
In line 16 there's a GT0 CF but LBL "CF" is nowhere to be found. Is this a typo??
GTO C doesn't look likely either given where the instruction is: no previous test and no LBL after it.
Would be good if you can double check the listing...
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
05-19-2021, 03:33 PM
There is also a REGMOVE command, this code may need the XFunctions module ?
05-20-2021, 09:59 AM (This post was last modified: 05-20-2021 10:00 AM by Stevetuc.)
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
It looks like the CF flag is being used for indirection
Ie if CF= 03 GTO CF > GTO LBL 03
05-21-2021, 05:21 AM
(05-20-2021 09:59 AM)Stevetuc Wrote:  It looks like the CF flag is being used for indirection
I don't think so; if this was the case when are the instructions that follow executed?
05-22-2021, 01:11 AM
Is it a clever synthetic though? couldn’t you use the first (top) 10 keys as surrogates for 00-10 in STO and RCL and GTO?
I think a piece of the program is missing though, there aren’t routines sensitive to flag 03?
Todd
05-22-2021, 05:07 AM
(05-22-2021 01:11 AM)twdeckard Wrote:  couldn’t you use the first (top) 10 keys as surrogates for 00-10 in STO and RCL and GTO?
Yes, but 01-10.
02-19-2022, 10:40 PM
There might have been a typo at my hand. I will rescan the tapes and see if I can transcribe them better. I've seen mention of some USB hardware that might be of use but no idea what i need to do to make that a reality
02-20-2022, 12:15 AM
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
Yes, this should be GTO "C"
02-20-2022, 05:06 AM (This post was last modified: 02-20-2022 05:18 AM by WrongWay.)
I tried compiling this program and I can't seem to get it to run on V41, it gets to STO 50 and returns NONEXISTANT. How is it possible?
Answer: It requires Synthetic Programming
02-20-2022, 10:25 AM
Wrong way, did you pull the program down? could you repost it?
Best
Todd
02-20-2022, 11:16 AM
Best
Todd
02-20-2022, 11:44 AM
(02-20-2022 05:06 AM)WrongWay Wrote:  I tried compiling this program and I can't seem to get it to run on V41, it gets to STO 50 and returns NONEXISTANT. How is it possible?
Are you sure you were using the correct SIZE parameter ?
02-20-2022, 06:30 PM
Great question! I am not sure I am using the correct size parameter. This code was found in a box of magnetic strips and there is no documentation about it anywhere.
02-20-2022, 06:40 PM
JETLOG program attached. for some reason I can't attache raw files, but the zip file contains the raw
Attached File(s)
.zip  JETLOG.zip (Size: 1,017 bytes / Downloads: 10)
02-22-2022, 04:16 PM
The size appears to be 176.
02-25-2022, 10:14 AM (This post was last modified: 02-25-2022 10:17 AM by Ángel Martin.)
(02-20-2022 12:15 AM)WrongWay Wrote:
(05-13-2021 07:13 AM)Ángel Martin Wrote:  In line 16 there's a GT0 CF but LBL "CF" is nowhere to be found. Is this a typo??
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
I wouldn't think so, that would mean that the following two program steps are never executed:
SF 03
GTO "C"
FS? 00
GTO 01
LBL 00
It's probably more likely to be this, changing SF 03 with FS? 03:
FS? 03
GTO C
FS? 00
GTO 01
LBL 00
right?
