FRAM71B installation
01-28-2021, 08:53 PM
Quick question, please: is it mandatory to remove existing ports/modules, when installing the FRAM71B?
I am quite unable to remove my HP-IL module, and one front port module (port 2, CMT 32KB RAM). They just won't budge. Am I going to do damage, if I continue the install with those two still installed? Or is the reason for removal simply to exclude them as causes, in case of issues with the FRAM71B initial configuration? thanks very much… Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
01-28-2021, 09:28 PM
RE: FRAM71B installation
Never mind, and thanks for reading: I finally managed to get both out, without destroying anything (I hope).
01-28-2021, 11:27 PM
Although you've resolved it, the basic reason is to remove anything connected to the bus, to prevent possible interference or confusion with the initial setup process. In reality, it's unlikely the HP-IL module would interfere, but if it's not installed, it's 100% clear it wont.
Enjoy the fun, backup often, and please share any clever tricks you discover. --Bob Prosperi |
01-29-2021, 01:57 AM
thanks very much Bob.
When I got it out, I saw that the date-stamp on the base of the HP-IL module was 8826, within two weeks of the date code in the 71B serial number. So it may be that my unit has had that module in there from new, 32 years. No wonder it was reluctant to come out. I've only had it a year or so myself. thanks again. Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
01-29-2021, 07:31 AM
(This post was last modified: 01-29-2021 07:36 AM by Hans Brueggemann.)
(01-28-2021 11:27 PM)rprosperi Wrote: Although you've resolved it, the basic reason is to remove anything connected to the bus, to prevent possible interference or confusion with the initial setup process. In reality, it's unlikely the HP-IL module would interfere, but if it's not installed, it's 100% clear it wont. this is indeed the reason why the installation instruction asks you to remove the HP-IL module. your HP-71Bs have the tendency to shrink over time. On some specimens it is now almost impossible to remove the IL-module without applying excessive force, which should be avoided. So, i do recommend to those who have an HP-71B with "jammed" HP-IL module to not try to remove the module and just go ahead with the installation instructions. However, make sure that the AC-adaptor is disconnected and all batteries have been removed. |
01-29-2021, 01:27 PM
(01-29-2021 07:31 AM)Hans Brueggemann Wrote: On some specimens it is now almost impossible to remove the IL-module without applying excessive force, which should be avoided.On those units, I plug an HP-IL cable in the interface and use that as a lever to pull out the interface. Some HP-IL cables are easy to unplug from the HP-IL interface while some other are hard to unplug, use the latter. |
01-29-2021, 04:19 PM
(01-29-2021 01:27 PM)Sylvain Cote Wrote:(01-29-2021 07:31 AM)Hans Brueggemann Wrote: On some specimens it is now almost impossible to remove the IL-module without applying excessive force, which should be avoided.On those units, I plug an HP-IL cable in the interface and use that as a lever to pull out the interface. If modules 3 and/or 4 can be removed, a stuck HP-IL module can be pushed out from the back side using a small wooden dowel. Be careful. |
01-29-2021, 06:44 PM
thank you Hans, Sylvain, Dave & Bob.
A privilege to get such folk replying I hope I've not damaged my HP-IL module getting it out; I only used finger pressure (but considerable), so hopefully not. It went back in OK, and responds to VER$, so hopefully it is OK. I like Sylvain's cable idea I'd read your dowel suggestion before, thanks Dave, and considered it, but was extremely nervous about damaging something else, so stuck to fingernails. Come to that, I struggled a little getting the FRAM71B in, without pushing too hard on the pin connectors; the allen key sockets are sufficiently far away to cause it to tilt down, rather than go in, but I managed it in the end. And it's now working, thank you Hans Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
01-31-2021, 12:28 PM
as i've got a few e-mails recently that reported installing the FRAM71B would send the HP-71B into coma, here's a bit of insight to the how and why. your FRAM71B consists of two parts:
1. a 265k x 16 bit FRAM memory IC, and 2. an FPGA with all the logic gates required to properly interface the FRAM memory to the internal bus of the HP-71B normally, you would assume an FPGA to operate from a directly attached clock source, but in the case of FRAM71B there is no such source. instead, FRAM71B completely relies on your HP-71B's STR signal as the sole clock source for all internal operations. when the STR clock stops, your FRAM71B stops. if you are wondering when this is happening, consider the blinking cursor of your HP-71B: whenever the cursor changes state (from invisible to visible and vice versa), there is a short burst of clock cycles during which the HP-71B does its display update job and FRAM71(B) is actually "awake". during times when the cursor is either visible or not, the clock pulses are gone and your FRAM71(B) has stopped all internal activities. this is the way how FRAM71B achieves its low power consumption, but that comes at a price: when you switch [ON] your HP-71B, there are only so many clock cycles available to FRAM71B to organize its internals for proper operation before your HP-71B requests acces to its configuration registers. in fact, there are not enough clock cycles available for FRAM71B to re-load the configuration data from FRAM's 0x2C000 area into its internal config registers. instead, FRAM71B's config registers are simply overlayed on the same address space 0x2C000, so that a POKE"2C000","aaaa..." not only goes into FRAM memory but also into FRAM71B config registers. that means that as long as the power supply is good, FRAM71B's config contents will match the contents of the FRAM at 0x2C000 and there's no need to ever read the FRAM for configuration purposes. however, once power is lost even for a short moment, FRAM71B's config registers will contain data that may no longer match the FRAM data at 0x2C000. that's the reason why there might be a situation where your HP-71B freezes at [ON] although all data in FRAM are still valid. in order to overcome this, you can set CN2-2 to switch FRAM71B into "stealth mode". in this mode, FRAM71B can be configured via POKE"2C000","aaaa...", but its configuration will not go into effect until you remove CN2-2 and power cycle your HP-71B. here is a sequence how to do a configuration refresh after a power loss, if a simple POKE "2C000", PEEK$("2C000",32) doesn't work: Code: 1. switch the HP-71B [OFF] |
02-01-2021, 06:46 PM
(This post was last modified: 02-01-2021 06:56 PM by Hans Brueggemann.)
another question that came in via e-mail regarding programming of the FRAM71B:
you do not need a flashpro programmer to set up your FRAM71B configuration, a simple POKE command with configuration bytes will do. all FRAM71B have the most recent firmware V607. no need to update. find the most recent manual here: FRAM71B_V6xx Manual find Sylvain's excellent collection of related links here: Sylvain's FRAM71 related link collection |
02-02-2021, 02:43 AM
Hello Hans,
Good news, I have received one of the two FRAM71B module today, the other should come soon now. During my initial test, I have witness something that I had never realized.
Code: [OFF] → Powering off the computer Top board FRAM block 2 reset Code: [OFF] → Powering off the computer I understand that this is an edge case and I think I understand why, still, could you light up my lantern please. Sylvain |
02-02-2021, 04:58 AM
(This post was last modified: 02-02-2021 05:27 AM by Hans Brueggemann.)
sylvain,
FRAM71-1024 has its TOP FRAM soldered on top of its (standard) bottom FRAM. as a consequence, TOP FRAM is always write enabled, unless you declare it as ROM. FRAM71B-1024 has a 512 kByte extender board that comes with a dedicated WRITE ENABLE jumper. did you check that jumper? (hint: if you haven't yet set WRITE ENABLE, you may want to explore TOP FRAM's contents first. there was an easter egg hidden in the extender boards (highly experimental, there is a chance that not all modules function as expected. At least FORTH, FRTH-41 and MATH should function, though): Code: F0x30000: HRDFORTH (E0000 part) |
02-03-2021, 03:02 PM
Hello Hans,
I saw that the module was initially setup with top FRAM enabled, top FRAM write disabled and E0000 mapping enabled. I found that strange, so I plugged the module, saw that Forth was there and some other modules. I thought that it was tests leftover so I reconfigured the module then did a full cleanup of both top and bottom content. It was while doing that cleanup that I saw the unexpected behavior. Anyway, I have reread the FRAM71B manual and for some unknown reasons I had skipped some information in there that is specific to the second generation module. I just realized that all my pasts experiments has been done on the FRAM71 and used the FRAM71B with safe config only. I am back to square one, well, not exactly one but very near, so I need time to experiments FRAM71B specific options and edge cases. I have setup three 71B for testing:
Sylvain |
02-03-2021, 04:30 PM
(02-03-2021 03:02 PM)Sylvain Cote Wrote: I have setup three 71B for testing:The 2016 and 2021 modules are both H/W 105 and S/W 607. There shouldn't be any differences. I believe the pre-loaded ROM's were the Easter Egg. Dave |
02-03-2021, 05:20 PM
I should have order the 1Mb version... note to self!
(02-03-2021 04:30 PM)Dave Frederickson Wrote:(02-03-2021 03:02 PM)Sylvain Cote Wrote: I have setup three 71B for testing:The 2016 and 2021 modules are both H/W 105 and S/W 607. There shouldn't be any differences. |
02-03-2021, 06:23 PM
RE: FRAM71B installation | |||
02-03-2021, 06:35 PM
(02-03-2021 05:20 PM)KimH Wrote: I should have order the 1Mb version... note to self! the design files are all available here, and i'd guess that, as soon there is a larger audience requiring the extender, someone will surely jump in to crank out a few. the "easter egg" was a proof of concept for an adapter, that would allow for pre-programming of the FRAM71B on a TL866 II plus. that didn't go too well, but in the end i was able to come up with an adapter that can program the -512 extender with the TL866 in "one shot". will follow up in a separate thread, will also be including the design files. |
12-15-2021, 02:47 PM
Hello Folks,
after a long time struggling during COVID19 lockdowns, Homeoffice, changing my flat - I start again using my old calculator. It seems that in the two years there was some dust on it so I disassembled it cause the display didn't show anything in the middle of the screen - looks like that the "rubber" connector was the problem. After cleaning it runs smooth again :-) The only thing I faced, that after POKEing the approbate string again, my iRAM was gone. So I tried to claim it again but without success. What I'm doing wrong and how can I claim it again? best regards Erwin |
12-15-2021, 05:12 PM
try again doing a POKE"2C000", config$, but make sure that config$ is exactly 32 nibbles long.
example: if your config$ was "B3B4B5", then POKE "2C000", "B3B4B500000000000000000000000000" see also Q5 in chapter 13 of the "DENVER 2016" manual. |
12-16-2021, 08:08 PM
(12-15-2021 05:12 PM)Hans Brueggemann Wrote: try again doing a POKE"2C000", config$, but make sure that config$ is exactly 32 nibbles long. Hello Hans, I did this starting with POKE"2C000", ”D3E4D5D69718191A9BEEEF00” after that I saw that my iRAM is not present and did a POKE"2C000", "00 ... 32 times" and then the above one again but with the same result. I have no idea ... it is not possible to claim this IRAM port. It is 128kb MAIN RAM and 32kb IRAM additional to the other modules (MATH 2b, JPC04 FTH41, CIRCUIT and FINANCE) best regards Erwin |
