3D Printed Overlay for DM42, DM41X ...
02-11-2021, 04:05 PM (This post was last modified: 02-11-2021 04:19 PM by anetzer.)
enclosed please find the source file (.skp for SketchUp) and the .stl data for an overlay for the DM4x hardware.
I have also attached photos. I have however rotated the enclosed 3d files after printing these specimens so that a new print will put the rougher side below and the smooth side up.
I have used the Swissmicros specifications for design:
https://technical.swissmicros.com/graphi...y_DM42.PDF
I hope you find this useful.
Andreas
.zip  DM4x 3D Data.zip (Size: 39.9 KB / Downloads: 23)
02-11-2021, 08:00 PM
RE: 3D Printed Overlay for DM42, DM41X ...
Very nice! If one was able to switch filament colors mid-print, then legends should be possible.
Try CC41!
02-11-2021, 08:55 PM
(02-11-2021 08:00 PM)Craig Bladow Wrote:  Very nice! If one was able to switch filament colors mid-print, then legends should be possible.
Prusa i3 MK2.5S & MK3S/+ Multi Material 2S upgrade could do up to 5 colors...
02-11-2021, 09:07 PM
3D printing legends in different color
Don't be afraid of editing .gcode files. If your slicer can show layer-by-layer, then you can figure out when to insert a pause to switch filaments mid-print.
Alan
02-12-2021, 01:24 AM
(02-11-2021 08:55 PM)anetzer Wrote:  Prusa i3 MK2.5S & MK3S/+ Multi Material 2S upgrade could do up to 5 colors...
I have a Prusa MK3S which after this weekend will be a MK3S+. I believe you can schedule manual filament changes in the slicer software without the Multi-Material upgrade.
Try CC41!
02-12-2021, 11:16 PM (This post was last modified: 02-12-2021 11:20 PM by Craig Bladow.)
I ran a quick test, see attached. The results could be improved by using a smaller nozzle than the 0.4 mm used here and perhaps PLA vs. PETG (used here) which is a little more stringy.
Try CC41!
03-11-2021, 11:07 PM
Almost to the point of 3D printed double shot keycaps! Things are looking up!
It ain't OVER 'till it's 2 PICK
03-12-2021, 06:46 PM
In addition to the ability to change colors at a specific layer, it is also possible to approximate double shot keys by using a color change mid-layer. Essentially, you print all of the key backgrounds, leaving letter-shaped holes. Then you pause, change filament, and continue the print, which then fills in the letter-shaped holes with the second color.
I have a video bookmarked somewhere showing the entire workflow for doing something like this, if anyone is interested.
03-12-2021, 11:18 PM
(03-12-2021 06:46 PM)SAllendorf Wrote:  I have a video bookmarked somewhere showing the entire workflow for doing something like this, if anyone is interested.
I'm interested!
Try CC41!
03-13-2021, 07:01 AM
(03-12-2021 11:18 PM)Craig Bladow Wrote:  I'm interested!
https://www.youtube.com/watch?v=YS2s9fNvux8
The narration is in French.
03-13-2021, 12:05 PM
Merci, très instructif. / Thank you, very informative.
01-26-2024, 04:41 PM
Whywould you have to switch mid print. Just do it in two passes.
01-26-2024, 09:42 PM
It depends on how thick the print is, i.e. how many layers. If you go more than a couple layers between switching colors then the nozzle will drag on the outer layer.
Ideally you print layer 1 color 1, layer 1 color 2. Then layer 2 color 1 layer 2 color 2, then layer 3 color 1, layer 3 color 2. etc.
I want to replace the mainboard of mu printer with a dual extruder for dual colors.
01-27-2024, 01:59 AM (This post was last modified: 01-27-2024 02:00 AM by Craig Bladow.)
Since this thread began I now do two prints, one over the other. The first one is one layer high, the second print is printed on top. See the photo.
Try CC41!
01-27-2024, 11:44 PM
looks very good
01-28-2024, 12:48 AM
Hi Andreas,
I was more interested in your screen shot, cool offimg and chance of sharing.
Thanks
(02-11-2021 04:05 PM)anetzer Wrote:  Hello,
Andreas
01-28-2024, 02:35 AM
(01-28-2024 12:48 AM)RPLman Wrote:  Hi Andreas,
Thanks
Lots of similar ones starting here:
https://forum.swissmicros.com/viewtopic.php?t=2214
