HP-67 Conversion-Factors-Label
05-09-2021, 09:52 AM (This post was last modified: 03-25-2024 07:56 PM by tuxfan.)
After repairing an HP-67, I made a copy of the label on the back with a graphics program. Maybe it's useful to someone else too. If you want, you can download the copy of the label here
Password is hew-pack-67
After removing the original label, I put the copy on the calculator and kept the original for later.
I printed out the copy with a laser printer on normal paper and then treated it with a matt varnish. The label treated in this way was then attached to the calculator with a thin double-sided adhesive film.
11.05.2021
I've changed the pdf files. The resolution was too low.
11.05.2021
Correction of a typographical error (BRITISCH... to BRITISH...)
05-09-2021, 09:36 PM
RE: HP-67 Conversion-Factors-Label
Thank you for sharing!
05-11-2021, 12:51 PM (This post was last modified: 11-15-2022 06:23 PM by tuxfan.)
(05-09-2021 09:52 AM)tuxfan Wrote:  After repairing an HP-67, I made a copy of the label on the back with a graphics program. Maybe it's useful to someone else too. If you want, you can download the copy of the label here
I printed out the copy with a laser printer on normal paper and then treated it with a matt varnish. The label treated in this way was then attached to the calculator with a solid double-sided adhesive film.
05-11-2021, 02:57 PM
(05-11-2021 12:51 PM)tuxfan Wrote:  I've changed the pdf files. The resolution was too low.
Sorry, just found this: "1 BRITISCH THERMAL UNIT =..."
05-11-2021, 07:13 PM
Hello Massimo,
thanks for the hint.
I have now, hopefully, eliminated the last mistake.
Sorry to everyone for any inconvenience.
tuxfan
05-11-2021, 07:19 PM
(05-11-2021 07:13 PM)tuxfan Wrote:
(05-11-2021 02:57 PM)Massimo Gnerucci Wrote:  Sorry, just found this: "1 BRITISCH THERMAL UNIT =..."
Hello Massimo,
tuxfan
Sorry? Not at all, you're welcome! And thanks a lot.
06-04-2021, 03:28 PM
Thank you very much !!!
Edoardo & Alberto
06-05-2021, 12:12 AM
Great, thank you.
