Programming Helper Drop Down Menu
01-23-2022, 09:23 PM
(This post was last modified: 01-24-2022 12:53 AM by BERNARD MICHAUD.)
The Programming_Helper.hpprgm and the Catalog.hpprgm are
Drop_Down menus you can use, in the "Connectivity Kit EDITOR" as opposed to programming directly from the Prime calculator itself. It contains a variety of commands, Greek symbols, "Math" menu. The Catalog.hpprgm contains all of the commands found in the Prime "Catlg" menu. You can upload them from your "Content folder" and place them alongside your program and cut and paste them into your program. I find them very useful, and hope you will also. BM |
05-02-2022, 07:10 PM
RE: Programming Helper Drop Down Menu
They are a good help when programming the Prime on the PC.
Thanks for sharing them. |
05-03-2022, 05:12 PM
RE: Programming Helper Drop Down Menu | |||
08-05-2022, 12:29 AM
(01-23-2022 09:23 PM)BERNARD MICHAUD Wrote: The Programming_Helper.hpprgm and the Catalog.hpprgm are Thanks for the app. I tried to install it by dragging to the "Programs" on the connectivity kit. When i go to Shift-1, the files are empty and running them does nothing. Obviously I am doing something wrong - but I am at a loss what should be the right way? Some help please? Thanks |
04-15-2023, 03:12 AM
I'm not on my PC now so I can't first try, but I think you have to copy the files into the "calculator" subfolder of the connectivity kit that holds the apps and other program code. When you then launch the connectivity kit, the programs should be loaded.
