06-29-2024, 12:47 PM
Post: #221
(06-28-2024 11:45 PM)c3d Wrote:Quote:Concerning, the state saving function, I observed that I am not able to save the calculator state under a new name (useful if a want to communicate the precise configuration of a given problem). Doing Setup>State>Save state, leads to <New Files>; I then correctly enter a new Filename, but the calculator then prompts with - [R/S] to Confirm. And there I am stuck because the [R/S] key is inaccessible since the DM32 key template is gone. I tried any key (including [=]) with no success. One indirect way to circumvent this is to create copies of given states in the computer and upload them afterwards into the calculator. And then save my new states under these pre-existing named ones. It seems to only occur on DM32, not DM42. On the DM42, you finish entry using the ENTER key, not R/S. I tried that on the DM32, but it does not work either. I'm reflashing with the stock DM32 firmware to see how that works there. |
06-29-2024, 12:58 PM
Post: #222
(06-29-2024 12:47 PM)c3d Wrote:(06-28-2024 11:45 PM)c3d Wrote: Weird. This is indeed a bug, and indeed, the = key is the one you should use. But I can confirm it does not work, whether on DM42 or DM32. This is a regression, I'm pretty sure it used to work. I filed an issue. On DM32, the ENTER key emits the M key. So that's why file entry was moved to R/S. Hmm. Need to dig a bit deeper on how to address that. |
06-30-2024, 11:06 PM
(This post was last modified: 06-30-2024 11:20 PM by c3d.)
Post: #223
Release 0.7.9 - Bug fixes + WASM support
A new minor release 0.7.9 is out.
This release includes a number of bug fixes, facilitates build from scratch by third-parties, and delivers a WASM-based simulator that runs on the https://48calc.org web site. Features menu: Add Purge to the ClearThingsMenu purge: Add support for lists units: Accept units for sqrt, cbrt and xroot wasm: Add variant for 48calc.org wasm: Implement WASM support Bug fixes complex: Give Syntax error for phasor without an angle dms/hms: Parse empty numbers in DMS entry dms/hms: Protect display against bad input editor: Make sure we reposition after shift-up and shift-down parser: Parse degrees as an angle unit in phasors simulator: Avoid high CPU usage when a timer is active simulator: Use the correct color for firmware text ui: Compute the correct refresh rate even when nothing is displayed ui: Create a non-empty dirty rectangle when clearing annunciators ui: Do not refresh beyond LCD size ui: Ensure we redraw the shift region to clear busy units: Disable simplification during unit definition evaluation Improvements build: Fix the clean build object: Remove defaults for as_uint32 and similar parser: Cache parser::length when possible parser: Merge the parser::end and parser::length fields parser: Optimize integer parsing early exit simulator: Avoid Cancel in file save dialog simulator: Use https as a protocol for git submodules tests: Add support for degrees sign tests: Add test for polar angle conversion. units: Add factoring variable to limit simplifications wasm: Add link to deployed WASM simulator in the README wasm: Add script to add COOP / COEP headers wasm: Run the RPL thread in a separate thread |
07-01-2024, 06:51 PM
Post: #224
Simple procedural question for the updates...
Is it good practice to replace the various config files with each update? I have customized my units.csv file, so I typically don't update it, but I have been grabbing the other ones from the release assets (like characters, equations, library, constants, etc). Is this necessary? WP31S/WP34S, WP43/C47, newRPL (various), and DB48X adhesive and tabbed overlays: https://www.hpmuseum.org/forum/thread-20113.html |
07-01-2024, 07:16 PM
Post: #225
(07-01-2024 06:51 PM)spiff72 Wrote: Simple procedural question for the updates... It depends if I changed them ;-) For the last few releases, I have made only few changes to these files. The most recent, IIRC, is changes to the equations library to add units to variables. I will make a point from now on to indicate in release notes if the configuration files were updated. |
07-01-2024, 07:46 PM
Post: #226
(07-01-2024 07:16 PM)c3d Wrote:Great - that will be very helpful for me, at least!(07-01-2024 06:51 PM)spiff72 Wrote: Simple procedural question for the updates... WP31S/WP34S, WP43/C47, newRPL (various), and DB48X adhesive and tabbed overlays: https://www.hpmuseum.org/forum/thread-20113.html |
Yesterday, 05:53 PM
Post: #227
I have an possibly odd question.
My DM42 (running DB48x) is showing the low battery warning today for the first time. I figured that this is probably legit because the voltage indicator in the menu bar has been gradually decreasing, and it dropped below 2.6v now. I am at work but I have a stash of crummy CR2032 batteries here that I thought I could at least install and use until I get home and put a better quality battery in tonight. However, when I swapped in one of these suspect batteries, I still get the error message and can't use the calc unless it's plugged into USB power. I did check the battery voltage with a multimeter and it was about 3.1V before I installed it. I just pulled the back off the calc and carefully checked the voltage while it is installed and in the "on" state (currently displaying the low voltage warning). I measure 3.15v despite the voltage level being reported by the calc in the sub-2.6v range. Could something have changed in the latest FW version that might cause this? It seems like it's not reading the voltage correctly, but I never tried measuring the voltage in-circuit with previous FW versions. Thanks! WP31S/WP34S, WP43/C47, newRPL (various), and DB48X adhesive and tabbed overlays: https://www.hpmuseum.org/forum/thread-20113.html |
Yesterday, 05:58 PM
(This post was last modified: Yesterday 06:57 PM by spiff72.)
Post: #228
(Yesterday 05:53 PM)spiff72 Wrote: I have an possibly odd question. To add to the above... I checked the voltage of the battery that I removed, and it is showing about 2.78v (outside the calc - not in circuit). And to clarify how I am checking the voltage while in-circuit, I am touching the very edge of the big round pad on the PCB that the negative side of the battery touches (very carefully to avoid shorting the probe against both the pad and the edge of the battery), and touching the battery holder to get the + side contact. EDIT: I also tried reverting to the previous version but that didn't help. EDIT2: I tried flashing the latest C47 and it appears to report the same voltage with the BATT? command (around 2.49v), but that firmware doesn't pop up a message about replacing the battery. With the DB48x firmware, I can't even turn the calc off to get out of that error state. It's surprising to me that the voltage value available in the firmware differs from the voltage I can read at the battery. I will swap the battery for a better quality one when I get home tonight. WP31S/WP34S, WP43/C47, newRPL (various), and DB48X adhesive and tabbed overlays: https://www.hpmuseum.org/forum/thread-20113.html |
Yesterday, 07:33 PM
Post: #229
Press reset on back to reestablish calculator state?
Remember kids, "In a democracy, you get the government you deserve." |
Yesterday, 08:59 PM
Post: #230
(Yesterday 07:33 PM)mfleming Wrote: Press reset on back to reestablish calculator state? I'm not sure if you were replying to me, but I did try resetting the calc with the button on the back to see if the voltage reading changed or not. (It didn't). Eventually I figured out that if I turned plugged into USB with this "suspect" battery installed, and pressed exit a few times to clear the error message about low battery, I could turn it off, and then unplug it from USB and it stayed off. I swear I did this earlier and it didn't work, but I'm heading home now to replace my battery and see if things go back to "normal"! ;-) WP31S/WP34S, WP43/C47, newRPL (various), and DB48X adhesive and tabbed overlays: https://www.hpmuseum.org/forum/thread-20113.html |
Yesterday, 11:39 PM
Post: #231
As soon as cheap CR2032 batteries get below ~2.9V, they are unreliable. The DMCP is sensing the voltage under load and is attempting to display the actual voltage as seen with a load present, which is why it appears to be lower than the DMM is showing.
In any case, but a good quality CR2302 cell in (Energizer, Panasonic, Toshiba, etc.) and leave the cheap Chinese cells for other less demanding devices and you'll be OK. --Bob Prosperi |
Today, 12:36 AM
Post: #232
(Yesterday 11:39 PM)rprosperi Wrote: As soon as cheap CR2032 batteries get below ~2.9V, they are unreliable. The DMCP is sensing the voltage under load and is attempting to display the actual voltage as seen with a load present, which is why it appears to be lower than the DMM is showing. I put an energizer in it when I got home and that solved the problem. As I mentioned, the one I used earlier was from a VERY suspect batch that I vowed never to use again because they would go dead so quickly in just about any device. I'm showing a reading above 3v now on the status bar. I didn't check this one with a meter though... WP31S/WP34S, WP43/C47, newRPL (various), and DB48X adhesive and tabbed overlays: https://www.hpmuseum.org/forum/thread-20113.html |
