HP Prime Beta Firmware Version 2.2 Revision 15008
08-27-2024, 11:19 PM
(This post was last modified: 08-27-2024 11:21 PM by RobbiOne.)
Post: #101
RE: HP Prime Beta Firmware Version 2.2 Revision 15008
(08-27-2024 01:06 AM)dbrothers Wrote: On the Mac, the app in the Applications folder is a package file (it’s a file, so no subfolders). I did a Spotlight search for “firmware” and found several folders. One, by its path, was related to the Prime Connectivity Kit. Dragging the downloaded firmware file to this folder appeared not to work, but copy and paste did work. The MacOS apps are packages with a lot of files and subfolders, just use Show Packet Content in Finder contestual menu (left click on the .app file). The HP Prime firmware folder is inside the HP Connectivity Kit subfolder in the user Documents folder so copy new firmware inside it and the HP CK app will find it automatically. |
08-28-2024, 04:04 PM
Post: #102
It's been more than a week or two with no release yet. When can we expect the final release of version 2.2? I’ve been holding off on installing the beta, but if the final version is still some time away, is the current beta stable enough for regular use?
08-28-2024, 06:12 PM
Post: #103
(08-28-2024 04:04 PM)Insoft Wrote: It's been more than a week or two with no release yet. When can we expect the final release of version 2.2? I’ve been holding off on installing the beta, but if the final version is still some time away, is the current beta stable enough for regular use? Supposedly, the final will be out before the start of the school year (NOW! in some places) It's more stable than the previous shipping version (for me, anyway), especially with python programs so if you install it, you won't be sorry. Tom L Cui bono? |
08-29-2024, 01:27 PM
Post: #104
(08-28-2024 06:12 PM)toml_12953 Wrote:(08-28-2024 04:04 PM)Insoft Wrote: It's been more than a week or two with no release yet. When can we expect the final release of version 2.2? I’ve been holding off on installing the beta, but if the final version is still some time away, is the current beta stable enough for regular use? is Revision 15048 the current BETA still. |
08-29-2024, 01:35 PM
Post: #105
(08-29-2024 01:27 PM)Insoft Wrote:(08-28-2024 06:12 PM)toml_12953 Wrote: Supposedly, the final will be out before the start of the school year (NOW! in some places) It's more stable than the previous shipping version (for me, anyway), especially with python programs so if you install it, you won't be sorry. I have software build date 2024-07-21 rev. 15048 Tom L Cui bono? |
08-29-2024, 01:58 PM
Post: #106
(08-29-2024 01:35 PM)toml_12953 Wrote: I have software build date 2024-07-21 rev. 15048 Where did you get that? The latest I can see is 2024-02-09 15008 from here: https://www.moravia-parts.com/hp-prime/beta.html Current daily drivers: HP-41CL, HP-15C, HP-16C |
08-29-2024, 02:03 PM
Post: #107
(08-29-2024 01:58 PM)RPNerd Wrote:(08-29-2024 01:35 PM)toml_12953 Wrote: I have software build date 2024-07-21 rev. 15048 All links are available in this post |
08-29-2024, 02:46 PM
(This post was last modified: 08-29-2024 02:50 PM by RPNerd.)
Post: #108
(08-29-2024 02:03 PM)nbenm Wrote: All links are available in this post Thanks for that. I'll wait for the official release of 2.2 because I really can't be bothered to download each of the files in the firmware package individually. Edit: by following some more links I got to this page: https://www.moravia-parts.com/hp-prime/beta-b.html Current daily drivers: HP-41CL, HP-15C, HP-16C |
08-29-2024, 04:05 PM
Post: #109
(08-29-2024 02:46 PM)RPNerd Wrote:(08-29-2024 02:03 PM)nbenm Wrote: All links are available in this post I just updated mine, and while I’m not sure how easy the process is on PCs, it was straightforward on macOS. I simply unzipped the download, renamed the folder to "PrimeG2," and replaced the existing PrimeG2 folder in the firmware directory. After that, I performed the update. The process was simple, though once installed, it does display "BETA" in the top left corner of the screen. |
08-29-2024, 04:17 PM
Post: #110
(08-29-2024 04:05 PM)Insoft Wrote: I just updated mine, and while I’m not sure how easy the process is on PCs, it was straightforward on macOS. I simply unzipped the download, renamed the folder to "PrimeG2," and replaced the existing PrimeG2 folder in the firmware directory. After that, I performed the update. The process was simple, though once installed, it does display "BETA" in the top left corner of the screen. The process is pretty much the same on a Windows PC. I've done it on both Windows 10 and Windows 11. The "BETA" in the corner is a sensible precaution IMO. It reminds people that they're potentially using something that's still liable to change between then and the final, public release. It also shows you a screenful of disclaimer the first time it boots after an update. Current daily drivers: HP-41CL, HP-15C, HP-16C |
08-30-2024, 03:32 PM
Post: #111
(08-29-2024 02:46 PM)RPNerd Wrote: I'll wait for the official release of 2.2 because I really can't be bothered to download each of the files in the firmware package individually. Huh? There's only one file you need for G1 and one for G2. If you only have one calculator, you only need to download one file. Tom L Cui bono? |
08-30-2024, 04:09 PM
Post: #112
(08-30-2024 03:32 PM)toml_12953 Wrote: Huh? There's only one file you need for G1 and one for G2. If you only have one calculator, you only need to download one file. I've since found the relevant file(s) as I said in an edit to my previous post. The page linked to in the post I was replying to directed the viewer to other pages where each of the files contained in the relevant .zip files from HP was linked to individually. https://tiplanet.org/forum/archives_voir.php?id=4161871 (G1) https://tiplanet.org/forum/archives_voir.php?id=4161872 (G2) Current daily drivers: HP-41CL, HP-15C, HP-16C |
08-30-2024, 05:09 PM
Post: #113
RE: HP Prime Beta Firmware Version 2.2 Revision 15008 | |||
08-30-2024, 05:52 PM
Post: #114
(08-30-2024 05:09 PM)DavZell Wrote: I need to reinstall the Android Pro app. It was purchased. Do you know when the Pro version will be available on the Play Store again? I didn't save an APK. https://play.google.com/store/apps/detai...=web_share Current daily drivers: HP-41CL, HP-15C, HP-16C |
09-02-2024, 12:27 PM
Post: #115
Is it possible to downgrade back to the current release after installing the beta.
Had anyone downgraded after trying the BETA? |
09-02-2024, 01:50 PM
(This post was last modified: 09-02-2024 01:53 PM by StephenG1CMZ.)
Post: #116
(08-30-2024 05:09 PM)DavZell Wrote:(07-26-2024 05:55 AM)KlaasKuperus Wrote: Yes. The quickest solution is likely to be to buy an old Android phone (Android 8), specifically for running the old App. There has not been an app update for years now. https://www.hpmuseum.org/forum/thread-20...it+or+miss This thread details where it might run. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-02-2024, 05:58 PM
(This post was last modified: 09-02-2024 06:51 PM by ftneek.)
Post: #117
https://www.moravia-parts.com/hp-prime/beta.html Wrote:At the moment, there are no public beta downloads. The long awaited moment is here, the officially released firmware is available for download via the Connectivity Kit. I was able to download the new firmware via the macOS CK by following these steps:
- neek |
09-02-2024, 06:25 PM
Post: #118
(09-02-2024 05:58 PM)ftneek Wrote:https://www.moravia-parts.com/hp-prime/beta.html Wrote:At the moment, there are no public beta downloads. All I get is "Could not connect to the update server" Is they not a link to just download the files like the BETA |
09-02-2024, 06:31 PM
Post: #119
(09-02-2024 06:25 PM)Insoft Wrote: All I get is "Could not connect to the update server" It worked for me. - neek |
09-02-2024, 06:34 PM
Post: #120
Bonjour
En exécutant le logiciel de connectivité ce soir pour sauvegarder mon travail, celui-ci m'a proposé de télécharger la mise à jour du 01_09_2024 pour G1 et G2. J'ai accepté et chargé celle-ci puis fais la mise à jour de ma G2 (version 15147) et le BETA en haut à gauche a disparu. Hello When I ran the connectivity software this evening to save my work, it suggested that I download the 01_09_2024 update for G1 and G2. I accepted and loaded it, then updated my G2 (version 15147) and the BETA in the top left-hand corner disappeared. Sorry for my english |
User(s) browsing this thread: 37 Guest(s)
