Just ordered my first SwissMicros... DM42n
09-16-2024, 11:57 AM
I've owned HP 28C and 28S, and 32S - but those are sadly gone.
I currently own HP 48GX, 50g, 12C, and two 15C CEs But this will be my first SwissMicros. I've been waiting for the 42 release with the better hardware specs. Can't wait... Much to learn... |
09-16-2024, 12:59 PM
RE: Just ordered my first SwissMicros... DM42n
I also have a DM42n on the way.. not that i need another one... (i already own a DM42 which i then convert to a C47 ).. and the damn hobby is so expensive... and i cant tell my wife.. but, oh boy, i also cant wait.... :-P
09-16-2024, 01:12 PM
What do we know about the DM42n compared to the previous? I'm seeing USB C connection, faster speed x2 a bolder font and updated Free42? Anything else of note?
Hard to to choose against a DM32. |
09-16-2024, 01:25 PM
(This post was last modified: 09-16-2024 01:31 PM by Slasher006.)
USB-C is a big one in my book because i nowadays have more usb-c cables around then micro-usb. Also the doubled Flash memory. The increased speed is not so important. I also own a DM32 so i can choose what flavor of calculator i am in the mood for the day.
09-16-2024, 02:02 PM
Another possibly important difference is much larger RAM space. On my 42, there is ~32K RAM available, while the 42n has ~415K RAM (neither is empty, but you get the point). So a huge difference if you use a lot of programs, or huge programs and/or data (like big matrices).
--Bob Prosperi |
09-16-2024, 02:40 PM
RE: Just ordered my first SwissMicros... DM42n | |||
09-16-2024, 02:44 PM
I'm hoping I will be able to run DB48X on it (or is it DB50?), and also hoping that I can switch back and forth to the OEM firmware - but I have to figure out how all this works - I'm a complete newbie on this stuff.
(Since I grew up on the 28S, I prefer RPL over RPN programming) |
09-16-2024, 02:50 PM
09-16-2024, 09:32 PM
09-17-2024, 11:18 AM
(This post was last modified: 09-17-2024 12:25 PM by c3d.)
(09-16-2024 02:44 PM)Jase Wrote: I'm hoping I will be able to run DB48X on it (or is it DB50?), and also hoping that I can switch back and forth to the OEM firmware - but I have to figure out how all this works - I'm a complete newbie on this stuff. As the author of DB48X, I was curious too, so I asked SwissMicros, and they told me that anything that runs on a DM32 should run on the DM42n. So that would be DB50X (DB48X is the exact same software at the moment, but built for the DM42). Please report your findings. ⚙️,?,? |
09-17-2024, 12:06 PM
Yesterday, 12:19 AM
(09-17-2024 11:18 AM)c3d Wrote:(09-16-2024 02:44 PM)Jase Wrote: I'm hoping I will be able to run DB48X on it (or is it DB50?), and also hoping that I can switch back and forth to the OEM firmware - but I have to figure out how all this works - I'm a complete newbie on this stuff. Doesn't DB50X require the DM32 keyboard with two shift keys, yellow and blue? The 42n still has the 42 keyboard with only the yellow shift key. To run DB50X on the 42n would require key stickers and a new bezel (or a memory much better than mine!) Tom L Cui bono? |
Today, 04:51 AM
I'm also deciding between a DM32, DM42n, and a second-hand DM42 for a bit cheaper.
Pros of the DM32: * Faster hardware * Unit conversions easily available (e.g. °F to °C, lbs to kg) * DB50x target with 2 shift keys Pros of the original DM42: * Cheaper * Supports C47 as well as DB48x * Matches free42 * Classic Pros of the DM42n: * Faster hardware * Matches free42 Is it possible to buy a DM42n or a DM32 and cross-flash it to the other firmware, with just a new keyboard overlay? Also, has anyone actually used DB48x on the DM42n yet? Thanks! |
Today, 12:09 PM
I have ordered an DM42n from Swiss Micros. I think I will be switching calculator-programming to that new machine from the HP41CX to use named variables (instead of memory registers) and the enhanced features of the free42 that are currently implemented in the DM42n.
Looking forward to learning more about the new DM42n at the HHC2024. I am packed and ready for my Lyft ride to the airport. For those folks who are attending the conference, I am looking forward to seeing you and enjoying the "Geek Fest", as my wife calls it. Namir |
Today, 03:39 PM
(09-16-2024 11:57 AM)Jase Wrote: I've owned HP 28C and 28S, and 32S - but those are sadly gone. Excellent choice! |
Today, 03:40 PM
(Today 12:09 PM)Namir Wrote: I have ordered an DM42n from Swiss Micros. I think I will be switching calculator-programming to that new machine from the HP41CX to use named variables (instead of memory registers) and the enhanced features of the free42 that are currently implemented in the DM42n. I'm ready to geek out and will be bringing my original DM42 (with the micro USB) with me. |
User(s) browsing this thread: DGM, 9 Guest(s)
