HP 50g Giving results for an indefinite calculation
10-11-2024, 07:00 PM
My HP 50g is giving results for |LN(-1.5)| and other negative numbers it is also showing a graph of this function in which it has a domain in the negative numbers, I've tried disabling Complex but it does not work
Note: For the calculator to graph with absolute values it has to have the rigorous flag enabled |
10-12-2024, 10:53 AM
(This post was last modified: 10-12-2024 11:04 AM by Gilles.)
RE: HP 50g Giving results for an indefinite calculation
(10-11-2024 07:00 PM)Cloud Wrote: My HP 50g is giving results for |LN(-1.5)| and other negative numbers it is also showing a graph of this function in which it has a domain in the negative numbers, I've tried disabling Complex but it does not work I have the same behavior... Maybe it's for HP48 compatibility? -1.5 LN returns a complex number even in real mode |R Same for the square root etc... And ABS returns the 'module' (in French, I don't know the English word) for a complex number and it gives a real. |
10-12-2024, 12:40 PM
RE: HP 50g Giving results for an indefinite calculation | |||
