HP 50g Giving results for an indefinite calculation
10-11-2024, 07:00 PM
My HP 50g is giving results for |LN(-1.5)| and other negative numbers it is also showing a graph of this function in which it has a domain in the negative numbers, I've tried disabling Complex but it does not work
Note: For the calculator to graph with absolute values it has to have the rigorous flag enabled
10-12-2024, 10:53 AM (This post was last modified: 10-12-2024 11:04 AM by Gilles.)
RE: HP 50g Giving results for an indefinite calculation
(10-11-2024 07:00 PM)Cloud Wrote:  My HP 50g is giving results for |LN(-1.5)| and other negative numbers it is also showing a graph of this function in which it has a domain in the negative numbers, I've tried disabling Complex but it does not work
I have the same behavior... Maybe it's for HP48 compatibility?
-1.5 LN returns a complex number even in real mode |R
Same for the square root etc... And ABS returns the 'module' (in French, I don't know the English word) for a complex number and it gives a real.
10-12-2024, 12:40 PM
(10-12-2024 10:53 AM)Gilles Wrote:  ... ABS returns the 'module' (in French, I don't know the English word) for a complex number and it gives a real.
The English equivalent would be "modulus" but the usual term is just "absolute value", which is used in the HP manuals and the English Wikipedia.
