Need Advice on Cleaning 48GX Battery Contacts
10-28-2024, 10:48 PM
Need Advice on Cleaning 48GX Battery Contacts | |||
10-28-2024, 11:47 PM
RE: Need Advice on Cleaning 48GX Battery Contacts
The usual recipe is white vinegar, which is acidic and reacts with the corrosion. Then water to kind of neutralize the vinegar. Finally, alcohol to remove any remaining residue and help the water evaporate.
10-29-2024, 12:07 AM
(10-28-2024 11:47 PM)Dave Frederickson Wrote: The usual recipe is white vinegar, which is acidic and reacts with the corrosion. Then water to kind of neutralize the vinegar. Finally, alcohol to remove any remaining residue and help the water evaporate. Great confirmation. After panicking, I went to YT and the video I found said the same. It's not perfect, but MUCH better. Thanks for the confirmation. Also, done with Duracell. Ordered some Energizer Ultimate Lithium batteries. |
10-29-2024, 07:30 AM
I don't think you can blame Duracell, but Lithium primaries are said never to leak.
They cost big money but I use only the lithiums in my gear since about 5 years ago. The older things get the more they become irreplacable... It ain't OVER 'till it's 2 PICK |
10-29-2024, 01:25 PM
(10-29-2024 07:30 AM)HP67 Wrote: Lithium primaries are said never to leak. I read that too, and that's when I decided to take the plunge. (10-29-2024 07:30 AM)HP67 Wrote: They cost big money YES they do! The AAAs I ordered from Jeff Bezos cost about $2.25 per battery. But as you said, that will be worth it if they never leak. Plus I read where people said they last a super long time. We shall see. |
10-29-2024, 06:21 PM
(10-29-2024 01:25 PM)Jase Wrote:my 2 cents. I no longer use disposable batteries, both for leakage problems and to preserve the excosystem. I only use low self-discharge rechargeable batteries. In the end they are also a financial saving.(10-29-2024 07:30 AM)HP67 Wrote: Lithium primaries are said never to leak. Hardware: Hp48S - Hp50g (5x black + 1 blue) - HP39gII - Hp27s - Casio fx-CG50 |
