CC41 RPN Calculator
11-19-2024, 06:11 PM
Post: #41
RE: CC41 RPN Calculator
(11-19-2024 02:03 AM)Craig Bladow Wrote: STOST XXX and RCLST XXXNice idea. Is this in any module in MCODE? HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
11-20-2024, 05:09 PM
(This post was last modified: 11-20-2024 06:22 PM by qgrdne.)
Post: #42
Thanks for the feedback Craig and the quick fix.
Most of the programs for the hp-67 also work on the hp-41c. For easy access, labels “A through E” and “a through e” have special meaning. For example, pressing the “A” key starts a program from label “A.” This also works with an hp-41c, if the USER key is activated. It seems that cc41 does not support this. Is that a deliberate choice? |
11-20-2024, 08:10 PM
Post: #43
(11-20-2024 05:09 PM)qgrdne Wrote: Thanks for the feedback Craig and the quick fix. Supporting local label execution by typing the label, say "A" followed RETURN in USER mode should be doable. The only reason it hasn't been done yet is I found the USER mode global label execution feature more useful for the way I was using CC41 at the time. The only complication would be that 'b' or 'B' currently works as a shortcut for BST and that would have to change in USER mode. I've added your request to the features list. Cheers, Craig Try CC41! |
11-20-2024, 08:46 PM
Post: #44
(11-20-2024 08:10 PM)Craig Bladow Wrote: ... The only complication would be that 'b' or 'B' currently works as a shortcut for BST and that would have to change in USER mode. Back in the last century when I was using my 41 every day I found annoying that BST was a shifted function, so promptly BST on the TAN key became part of my user setup, same as other programming functions (PROMPT, for example) that I used more often than trigonometric functions. With very small variations it is the setup I use to this day |
11-21-2024, 08:54 AM
Post: #45
Thanks for the reply Craig about the shortcuts.
The shortcuts for SST and BST (s and b) are very convenient. I wouldn't change that. The manual “CC41 User Manual.pdf” states that “XEQ TVM” is the same as “.TVM”. It turns out that “.A” is also a shortcut for “XEQ A”. So the easy access for “A to E” and “a to e” can be done by placing a dot (“.”) before the local label name. This works independently of the USER mode. So there is no need to change or modify “cc4”. |
11-21-2024, 11:08 AM
Post: #46
(11-17-2024 06:12 AM)Craig Bladow Wrote:(11-17-2024 05:29 AM)zixingcheche Wrote: I found the way.I'm glad you got it working, CC41 doesn't require a specific filename extension, as long as the file is a text file. And we must not forget the program launch parameters: Code:
We can therefore do : save myprog.txt in the text editor then cc41.exe -l myprog.txt which allowed me to add a link to CC41 in my "41CX interface" ! http://ti58c.phweb.me http://clones.phweb.me http://www.instagram.com/ti58c "No! Do or Do not. There is no try!" [Master Yoda] |
11-22-2024, 01:12 AM
Post: #47
(11-20-2024 08:46 PM)born2laser Wrote:(11-20-2024 08:10 PM)Craig Bladow Wrote: ... The only complication would be that 'b' or 'B' currently works as a shortcut for BST and that would have to change in USER mode. Same here! I guess great minds think alike :-) |
11-22-2024, 05:21 AM
Post: #48
(11-21-2024 08:54 AM)qgrdne Wrote: Thanks for the reply Craig about the shortcuts. That is good news! Try CC41! |
11-22-2024, 05:45 AM
Post: #49
Improvements made to DOW in CC41 resulted in revised date validation routines that are also used by DDAYS and DATE+. The earliest valid date allowed by the HP 41CX is October 15, 1582, the first day of the Gregorian calendar. Any earlier date results in an OUT OF RANGE or DATA ERROR/X/Y.
October 15, 1582 is accepted as valid by DATE+, DDAYS and DOW as an input but not as a result of a DATE+ operation! Code:
I get the same result in V41 and on my halfnut 41CX manufactured in 1986. Surely this is a known bug? Cheers, Craig Try CC41! |
Yesterday, 05:33 AM
(This post was last modified: Yesterday 05:33 AM by Craig Bladow.)
Post: #50
v0.45.04 alpha can now be downloaded from the GitHub link in the first post or in my signature below.
The zip file containing the executables for MacOs, Linux and Windows, along with the manual, can be found by clicking on the tag on the right hand side of the web page labeled "Releases". Many thanks to qgrdne for reporting an issue with DOW. Changes in this release include: New command GETPR which loads and runs a program. New commands STOST and RCLST which save and recall stack registers X,Y,Z,T, and L. DOW, DATE+, DDAYS improved functionality and error checking. Fixed case where a running program incorrectly stopped for some errors and flag 25 was set. Implemented initial functionality for Flag 24, OUT OF RANGE error ignore. Modified CAT command to default to CAT 3 when nonexistent catalog is requested. Improved detection of line numbers vs. numbers when loading a program. Try CC41! |
Yesterday, 07:54 AM
Post: #51
(Yesterday 05:33 AM)Craig Bladow Wrote: v0.45.04 alpha can now be downloaded Thanks for this Christmas gift ! MERRY CHRISTMAS http://ti58c.phweb.me http://clones.phweb.me http://www.instagram.com/ti58c "No! Do or Do not. There is no try!" [Master Yoda] |
User(s) browsing this thread: jeanwilson, 3 Guest(s)
