Graphical output HP Prime
03-18-2015, 10:46 AM
Try to output an Arc to the graphical screen with this code
HAngle:=0; //Degree RECT_P(0,0,319,239,RGB(255,255,255); ARC_P(0,159,119,50,40,90,RGB(0,0,0); HAngle:=1; //Radians The intension is to draw a arc starting at 40 Degree->90 Degree What is doing wrong. |
03-18-2015, 11:11 AM
(This post was last modified: 03-18-2015 11:16 AM by Thomas_Sch.)
RE: Graphical output HP Prime
(03-18-2015 10:46 AM)Powersoft Wrote: Try to output an Arc to the graphical screen with this code - some missing brackets? - HAngle seems to be ignored. The manual is probably not correct: "a1 and a2 follow the current angle mode and are optional. The default is a full circle." Code: EXPORT tst() |
03-18-2015, 11:21 AM
(This post was last modified: 03-18-2015 11:33 AM by DrD.)
The values for HAngle are inverted: 0 = Radians mode
1 = Degrees mode You can directly test this via the HOME command line. It is shown otherwise in user guides, and has been reported for change. Code:
03-18-2015, 06:37 PM
(03-18-2015 11:21 AM)DrD Wrote: The values for HAngle are inverted: 0 = Radians modeHello Dale, Thanks for the clarification! I didn't check the docs. Once again, the community is very valuable. |
