Graphical output HP Prime
03-18-2015, 10:46 AM
Try to output an Arc to the graphical screen with this code
HAngle:=0; //Degree
RECT_P(0,0,319,239,RGB(255,255,255);
ARC_P(0,159,119,50,40,90,RGB(0,0,0);
HAngle:=1; //Radians
The intension is to draw a arc starting at 40 Degree->90 Degree
What is doing wrong.
03-18-2015, 11:11 AM (This post was last modified: 03-18-2015 11:16 AM by Thomas_Sch.)
RE: Graphical output HP Prime
(03-18-2015 10:46 AM)Powersoft Wrote:  Try to output an Arc to the graphical screen with this code
HAngle:=0; //Degree
- some missing brackets?
- HAngle seems to be ignored. The manual is probably not correct: "a1 and a2 follow the current angle mode and are optional. The default is a full circle."
EXPORT tst()
  HAngle:=0; //Degree
  local arc:=π/180;
  RECT_P(0,0,319,239,RGB(255,255,255));
  ARC_P(159,119,1,RGB(0,0,255));
  ARC_P(159,119,48,RGB(0,0,255));
  ARC_P(159,119,50,40*arc,90*arc,RGB(0,0,0));
  WAIT();
03-18-2015, 11:21 AM (This post was last modified: 03-18-2015 11:33 AM by DrD.)
The values for HAngle are inverted: 0 = Radians mode
1 = Degrees mode
You can directly test this via the HOME command line. It is shown otherwise in user guides, and has been reported for change.
EXPORT tst()
  HAngle:=1; //Degree
  RECT();
  ARC_P(159,119,50,40,90,RGB(0,0,0));
  HAngle:=0; //Radians
  freeze;
03-18-2015, 06:37 PM
(03-18-2015 11:21 AM)DrD Wrote:  The values for HAngle are inverted: 0 = Radians mode
1 = Degrees mode
Hello Dale,
Thanks for the clarification! I didn't check the docs.
Once again, the community is very valuable.
