Global Variable
03-20-2015, 06:53 PM
Global Variable
This is a simple test.
Try to fill this EXPORTED var3 with subroutine. var1 and var2 have values, but var3 keeps on zero. What is wrong on this? Cheers, Jan TEST(); // Declaration of the subroutine EXPORT var1,var2,var3; //Exported variable EXPORT F1 () BEGIN TEST(); // Call TEST and fill var3 with value INPUT({var1,var2},{"var1=","va2="}); RETURN var1+var2; END; TEST() BEGIN var3:=12345.6789; END; |
03-21-2015, 02:02 PM
(This post was last modified: 03-21-2015 02:54 PM by DrD.)
RE: Global Variable
Changed the INPUT(..) line. This should work:
03-21-2015, 08:23 PM
RE: Global Variable
(03-20-2015 06:53 PM)Powersoft Wrote: This is a simple test.Your program works fine on my Prime as is. I get var3 value as assigned. I have the same firmware and Model as you. Runs fine on both the emulator and the real Prime. |
03-22-2015, 02:30 AM
RE: Global Variable
(03-20-2015 06:53 PM)Powersoft Wrote: This is a simple test. Check and see if var3 isn't also an already existing variable (prior to creating your program). Graph 3D | QPI | SolveSys |
