Auto-Off Timeout Change value
02-10-2016, 04:52 PM
I have the habit of performing calculations and write something but often it takes more than 5 minutes. This is the standard time for the calculator to enter auto off mode.
But those who wish to change this time is easy.
The TOff command shows the time in milliseconds and to see the value in seconds type TOff / (60 * 1000).
[Image: 8mJcg.jpg] [Image: 0h3MI.jpg]
To change, simply enter TOff: = # 927C0h to 10 minutes for example
[Image: 1xHAl.jpg]
Valid values are between #1388h to #3FFFFFFFh
You can enter lower values, 2 minutes, to save battery it:
TOff:=#1D4C0h
Leo
02-10-2016, 07:23 PM
RE: Auto-Off Timeout Change value
Hello jrozsas,
please have also a look at this little program by Wolfgang:
http://www.hpmuseum.org/forum/thread-2815.html
02-11-2016, 09:09 AM
(02-10-2016 07:23 PM)Thomas_Sch Wrote:  Hello jrozsas,
Nice program Thomas!
Product Manager HP for MORAVIA Consulting, the EMEA & AP Licensee for HP Calculators.
http://www.hpcalcs.com
02-11-2016, 12:08 PM
Thanks.
The honor goes to Wolfgang.
I added only the slider.
02-11-2016, 01:19 PM
There are several programs that are changing the shutdown time.
This is another one that also does the same function: https://www.cemetech.net/programs/index....le&id=1291
However, the change in command line seems to be simpler, especially when there is no need for constant change. It is also important that people know that the statement that really makes this change.
Leo
02-12-2016, 07:45 PM
(02-11-2016 01:19 PM)jrozsas Wrote:  ..
I see.
Youd didn't check this one?
02-12-2016, 08:53 PM (This post was last modified: 02-12-2016 08:54 PM by jrozsas.)
I see.
I installed them and work very well. Including serving as an example to the slidebar.
The command element (0..5) could be used to create the slider?
See: http://en.hpprime.club/docs/reference/element
Leo
02-12-2016, 09:12 PM
(02-12-2016 08:53 PM)jrozsas Wrote:  I installed them and work very well. Including serving as an example to the slidebar.
Thanks for the tip! Sounds very interesting.
Refering to the manual, (User_Guide_EN_2015_06_17_1.pdf, pg 184), 'element' belongs to the geometry app.
It is time to take a deeper look at this app ...
